I have a total of 6 Ford Super Duty Diesel Trucks ranging from 04 to 06 and all the fuel tanks i had to replace ford turned there head left me hanging unless I was paying for them I was over the warranty Milage but sure this is a huge defect.
What size tanks, am having a problem with tank lining comming loose and findind metalic flakes in both fuel filter, now have hard/ rough start, horriable running "misfire, shaking" Its a 04 F450 dump with 45,000mi and never ran bio.
Yes that is the problem there are 1000's of people with the same issue the inside of the tank lining peels away and clogs the whole system and nothing but problems
this is a defect ford told me that when the government made new regulations the fuel industry added stuff to the Diesel that ford tanks were not ready for..
There will be a class action suite its all over the net I have spoken to a lawyer but i would have to pay out of pocket to hire him.
Originally Posted by bismic
Did you just miss the questions on bio or additives?
I wish I could sue all the companies that sold me gasoline engines that were put in my lawn mowers and garden tractor. They run like crap with E10 the only fuel available to me.
So it's Ford's fault they didn't warn owners back in 05, and 06 not to use biodiesel?
Apparently this is not a biodiesel issue w/ the OP or vlietracer64 ......
Although biodiesel will definitely cause the delamination - and Ford did say not to use over B5. The additive question was a good one also. If straight diesel were the ONLY issue, then ALL tanks would be having the problem. Maybe they are, I do not follow these failures very closely.
we see it alot. its nothing new and we see it more this time of year. bio, water, alcohol can all cause it to happen.
this is not a ford defect this is a goverment tree hugging issue.
