Heater question
Old Nov 9, 2010 | 08:37 PM
  #31
tardster's Avatar
tardster
Originally Posted by BlueOvalRage
You might also double check that the thermostat is installed the right way. If it's backwards, it will never open. The spring side goes towards the intake/engine. Like Ross mentioned, air in the system can cause weird stuff like this also. The small block Fords usually fill and burp easily. Did you fill it cold and then just cap it? If so, you could have some big air pockets. Fill the radiator cold and then start the engine with the radiator cap off. Leave it off while the engine warms up and add coolant as necessary. Put the cap on when the thermostat opens and it should be good. You'll know when the stat opens because the upper radiator hose will suddenly get hot and the coolant in the radiator will start circulating and steaming a bit.
Yes I have it installed right but think maybe its pinched somehow, that thing was a PITA to get in after putting the bypass hose on so it could have moved around. I did fill it cool but started the truck and let it run a few minutes before putting the cap on but I didnt let it get warm enough for the thermostat to open. If its decent over the weekend I'll see if I can check it out and get it fixed...
Davydee
Feb 21, 2017 05:48 PM
ttaylor530
Aug 25, 2011 05:07 AM
eallanboggs
2004 - 2008 F150
Dec 13, 2010 12:26 PM
tps93ranger
1983 - 2012 Ranger & B-Series
18
Dec 4, 2009 06:07 AM
nickmobile67
Nov 13, 2008 07:38 PM
