Heater question
Old Nov 4, 2010 | 11:53 PM
tardster's Avatar
tardster
Heater question
My heater doesn't seem to be working. I dont see any leaks on the floor board and the blower is working but its blowing cold air out. I have a thermostat in and you can see its working, once it hits 190 it drops back down around 170-ish so I'm at a loss on what to do.
Old Nov 5, 2010 | 01:11 AM
fordman75's Avatar
fordman75
Check your heater hoses under the hood by the firewall for a valve. I believe there should be one that was originally operated by a cable. It allows you to shut off the flow of coolant to the heater core. I'm guessing you have one and it's closed.
If you don't have one my 2nd guess would be your heater core could be plugged up so it's getting no coolant flow thru it.
Old Nov 5, 2010 | 01:23 AM
tardster's Avatar
tardster
Yea as far as I know I dont have any valves on the hoses so maybe its plugged up. I guess I'll have to take the hoses off and put the garden hose on and see if I can flush it out.
Old Nov 5, 2010 | 01:39 AM
fordman75's Avatar
fordman75
It's been a while since I messed with any of the stock heaters. I don't remember if any of them had any kind of selector door/flap to control the air flow in the heater box. If it does that could be shut to block the heater core from the air flow.
You might want to check into that first and if it's not that then pull the hoses and check the heater core for blockages. You could also check the heater hoses while the engine is running and warmed up and see if either are warm/cool. That would at least tell you if the coolant is getting to the heater core.
Old Nov 5, 2010 | 01:58 AM
Julies Cool F1's Avatar
Julies Cool F1
Don't try flushing the heater with the garden hose, you'll blow up the core.
Start the truck and warm it up. Hold the heater hoses in your hand. They should both be warm. If not, you either have them hooked up in the wrong places, or the nipples coming out of the outlet or going to the inlet is plugged up.
Your heater hose should run off the nipple coming off the intake manifold to the lower heater inlet. It comes out the upper tube then goes back to the 1/2 inch tube extending out from the water pump on the passenger side.
If you didn't replace those two tubes when you rebuilt your 289, then chances are they are rusted up. Again check both of these tubes for a shut off. Normally it's the one on the intake manifold and it will have a little butterfly type twist on the top to open and close the valve.
If when you hold the heater hoses they are both warm, then the core is heated up, you just have a temperature door closed or the controls are frozen/not connected properly.
Old Nov 5, 2010 | 02:18 AM
tardster's Avatar
tardster
I wonder if I could have them hooked up wrong then. Both of my hoses come off the water pump. If you look in my engine gallery at the last picture you can see both of the hoses comming off the water pump, could that be the reason why?
Old Nov 5, 2010 | 02:28 AM
tardster's Avatar
tardster
Oh by the way Julie, do you have a diagram for the heater switch, I want to make sure the 3 wires that go to the back of the switch are hooked up correct.
Old Nov 5, 2010 | 04:07 AM
big job's Avatar
big job
An old saying
My father pounded in my head his old saying in relation to heater hoses.
"bottom to top and top to bottom" just remember that.
If confusing > the bottom of the heater core goes to the top of the
engine (usually the head) and the top of the heater core goes to the
bottom (usuall the water pump) and also on some systems its a real
pita to get an air pocket out. Symtoms usually are no heat, a high rise
in engine temp until the thermostat opens, then a little heat, then it
goes to cold. My family ran a bus fleet in the fiftys. Lets say we are
to replace the water pump. (engine in rear) 20min for a new pump and
2Hrs to bleed the heaters. These buses as well a school buses with
3 heaters they usually have bleeders on the cores. So you will have to
crack a heater line with the engine running Just a little so you dont get
burnt. If this does not work=then the core is blocked, 100% of the
time its due to over the years/and stop leak. To me stop leak is like
snake oil its a heater core killer.
Old Nov 5, 2010 | 05:12 AM
tardster's Avatar
tardster
Well I do believe my hose are wrong then, the top on the heater core goes to the top on the water pump and ythe bottom to the bottom of the pump. I am confused tho because both my hoses are on the water pump, is that right?
Old Nov 5, 2010 | 10:48 AM
Julies Cool F1
Honestly, my feeble brain doesn't remember my 289. And I'm not sure why you have two outlets coming from the water pump, but I would say yes they are not hooked up right. But, I'll get into my book to see.
Look on the top of your intake manifold in front of the carb and slightly to the right (pass) side. There should be a place to screw in a nipple - it might be plugged at the moment. Pic:
That's where the coolant should be coming from for the heater. And as mentioned, that should go to the lower heater tube. The outlet hose should go to the water pump - the upper one you have on there now, and the other inlet on the water pump plugged.
So, yes I'd say you need to hook them up differently!
On your heater switch, if you have the two position pull type, one of the terminals should have a "B" next to it. Power goes in there. The other two wires can go in either of the remaining terminals.
Old Nov 5, 2010 | 10:59 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You know, I recall 289's being different; take a look at his setup. It doesn't have the usual annoying bypass line (90-deg elbow) between the intake and WP. I can't think what else the two lines on the WP would be for.
Old Nov 5, 2010 | 12:48 PM
BlueOvalRage's Avatar
BlueOvalRage
You've definitely got them hooked up wrong. The upper of the two barbs on the water pump is supposed to have a short 90 degree bypass hose going to a small barb on the thermostat housing. As you've got it, both heater hoses are seeing suction from the water pump and there is no flow through the core. You need to get a bypass hose on it and hook the other hose up to the intake manifold at the port right behind the thermostat housing.
Old Nov 6, 2010 | 12:14 AM
tardster's Avatar
tardster
Ok I just want to make sure I got this right. I have a nipple that I can put on the thermostat housing that a hose can hook up to. I put the bottom barb on the heater core on that nipple then block off one of the barbs that is on the water pump and I should be good to go right. If thats right I will see if the fitting that is on the thermostat house that blocking the hole will fit on the water pump, if not I will have to presidentually solution the other babr on the water pump.
Old Nov 6, 2010 | 01:20 AM
Julies Cool F1
I don't remember the by pass arrangement on my 289 - maybe someone could take a pic for you - there's none of it in the Manual. On the 390 it comes in straight off the manifold forward to the back of the water pump (which is connected only on the wings not the entire face)
On your set-up as it is, all you need to do is remove the top hose going into the water pump and connect it to the outlet on the intake manifold just behind the thermostat housing (make sure that hose is on the top one of the two heater tubes as it shows in the diagram I posted). Then your heater hook up is ok.
But as Joe mentioned, you need to plumb your bypass then!
Old Nov 6, 2010 | 01:41 AM
tardster's Avatar
tardster
Julie in your diagram on the thermostat housing I have a place to put a barb or hose hook up. Can I put it there, its not blocked by the thermostat or does it have to be on the intake?
