Heater blend door problem
Old Nov 11, 2008 | 05:38 PM
nickmobile67's Avatar
nickmobile67
My 86 F150 with air, the switch between floor and dash vents stopped working. I took the face off of the heater core and I can see the door get stuck half way before it moves all the way over to floor vent position. Is this a common part to break? What do I have to do to fix it?
Old Nov 11, 2008 | 05:48 PM
Holmesuser01's Avatar
Holmesuser01
My 83 is doing the exact same thing. This will be interesting.
Old Nov 11, 2008 | 05:50 PM
Blindbatts's Avatar
Blindbatts
are you sure you don't just have a vacuum leak going to the switch?
Old Nov 11, 2008 | 07:11 PM
nickmobile67
no there's not a vacuum leak, the motor is working fine but the door is physically binding up when it gets about half way to the floor/defroster mode. I really don't want to take the whole box out of the truck. I put some duct tape on the hing side of the blend door to keep it from coming loose and binding but it only worked for about a week.
Old Nov 11, 2008 | 07:24 PM
86Stepside's Avatar
86Stepside
I just fixed the same thing on my truck a few weeks ago. If you take the top dash pad off, you'll get a better view of the ductwork, when you do that you'll see that the ductwork for the passenger side vents need to come out to access the "door". Since the door is broken you can probably see the hinge on the back to pull the pin out. Putting the new door in will be a little harder, especially if you have big hands, because you need to go through the hole next to the door to put the pin in the hinge. It took my a weekend to do it, including a trip to the junkyard for a replacement.
Old Nov 12, 2008 | 09:02 PM
Chevy_Eater's Avatar
Chevy_Eater
I just went through this myself. It's kind of tight, but you can do it without pulling the box. Like 86 said, pull the dash pad, then the braces and ductwork. Basically gut the top half of the heater to get to it. I couldn't find a new replacement and all the ones at the junkyard were either already broken or so weak and brittle they broke as I was removing them. What I ended up doing was cutting a couple of strips of inner tube, drilled some holes in both pieces of the door and used pop rivets to secure the tube pieces. Basically rebuilding the hinge with rubber. Works good so far.
Old Nov 13, 2008 | 04:55 PM
Holmesuser01
This is so ironic.
Last weekend, I replaced the heater core in a 1985 Oldsmobile Toronado. From start to finish, it took 9 hours. I had to pull the whole dashboard and instrument cluster, etc, just to get to the heater box. After I got the bad boy off of the firewall, it took about 5 minutes to actually replace the heater core. Its all plastic.
Now, it looks like I get to do a portion of this job again THIS weekend on a truck that has seen 4 owners before me, and the last 2 were heavy smokers. If for no other reason, I'll go ahead and pull the box from the firewall and clean it all up before I put it all back together. I was lulled into a false sense of security when I replaced the Ford core in less than 1 1/2 hours.
I'll let you know how mine goes.
As for the homemade parts, it will probably last forever in there.
Old Nov 13, 2008 | 07:38 PM
bigcountry1009's Avatar
bigcountry1009
Ahh, a lovely job. Did mine about 5 years ago and wish I had taken pics. I was quit proud of myself. My door broke off completely (84 by the way). Poor design. I went ahead and took the whloe dash out. If you"re gonna take the dash pad off, it"s really not much harder to take the rest of the stuff out. I used a stainless cabinet hinge with rivets and epoxy to bind it together. If you trim the door real careful and line the hinge up really good, you'll never have this problem again. I had the whole box out which made it much easier. just don't let taking the dash out scare you. It took me about three days cuz I couldn't devote more than a couple of hours to it. the truck drives just fine without the dash though. You'll be amazed at the junk you'll find behind the dash.
Ekrbse
Feb 11, 2017 11:17 AM
NTENSE
Oct 26, 2016 02:18 AM
treverd
Mar 30, 2016 09:31 PM
herdfan75
Dec 22, 2011 10:04 PM
BOTLFED98
Oct 15, 2007 02:53 PM
