High beam problems! Help?
Old Nov 4, 2010 | 10:22 PM
mattmeyer's Avatar
mattmeyer
Hey there guys! Have a minor problem with my 1991 f150. I recently installed new headlights because I believed were burnt out. Reason was because the little light on the dash didn't show up.. But there was a tiny change I could see regardless of the indicator light comming on. Slightly brigher. So I replaced all worked for about a week then bam back at square one same thing?
Any suggestions or help? Thanks matt!
Old Nov 5, 2010 | 12:12 AM
bubblegum's Avatar
bubblegum
Matt, what is the condition of the switch on the floor that you press with your foot to switch between low beams and high beams? I'm asking this because a while back while my truck still belonged to my boyfriend there was an issue with that switch, you'd have to step on it just right or it would not do anything. The light on the dash cannot be used to judge whether the headlamps are burned out or not as it seems to be wired together with them, and not after them - the light will come on even if you have the head lamps physically unplugged, as I found out once... If the switch on the floor is bad, however, there will be neither light on the dash, nor high beams up front.
Old Nov 7, 2010 | 07:16 PM
mattmeyer's Avatar
mattmeyer
That was exactly it! haha thank you! Didnt even see it under the floor mat, oh well very happy thats all it was!
Thanks
Old Nov 7, 2010 | 11:02 PM
bubblegum's Avatar
bubblegum
Glad I was able to help, I'm still learning about these trucks and what little I know is from me watching and/or helping others work on their trucks. That switch is very poorly placed, however, thankfully my boyfriend already moved it to where I can actually step on it good.
lawnman244
Jul 23, 2012 12:47 PM
bullet15963
Feb 12, 2009 01:12 PM
bentheplumber
Jul 5, 2007 12:04 AM
tcq142
Jan 2, 2006 12:41 PM
NitrousAl
1978 - 1996 Big Bronco
Nov 26, 2001 09:06 PM
