'94 taillight out
Old Feb 11, 2009 | 09:55 AM
bullet15963's Avatar
bullet15963
'94 taillight out
i have a 1994 f-150 xl and the problem is when i flick on the headlights the rear passenger light does not light up. But when i press on the brakes both the rear lights work just fine, with or without the headlights on. The bulb is fine because it uses the same bulb for the brake lights and headlights but i replaced it just in case and still nothing.
any help would be much appreciated
Old Feb 11, 2009 | 02:27 PM
nnero's Avatar
nnero
This same thing happened to me. Make sure the bulb is seated in the socket properly. Make sure you push the bulb in until you see it "snap" in.
This solved the problem for me.
Old Feb 12, 2009 | 09:44 AM
bullet15963
ok i doubled checked it and the problem is still the same
Old Feb 12, 2009 | 10:06 AM
nnero's Avatar
nnero
Its either that or maybe there is a ground problem somewhere. Check the condition of the socket and wiring. Thats the best advice I can think of. Maybe someone else knows more. Sorry. Its gotta be something simple though.
Old Feb 12, 2009 | 01:12 PM
bullet15963
ok ill check for a successful ground and hope that will work
choate
Jan 16, 2015 05:00 PM
hgoalie
Aug 30, 2013 04:59 PM
mdbbrown
Dec 28, 2012 01:26 PM
nateraz1
Dec 11, 2012 10:26 PM
kyle.good
Jul 8, 2011 10:22 PM
