ZF-6?
Old Nov 4, 2010 | 05:24 PM
fordzilla01's Avatar
fordzilla01
ZF-6?
Hi,
Also wondering if anyone knows how much power the ZF-6 can take before it will explode? (or cease to work anymore).
Thanks,
Old Nov 4, 2010 | 05:39 PM
robs01f250's Avatar
robs01f250
as long as the clutch can withstand the power you should be fine. They make clutches to handle more than 1000hp
Old Nov 4, 2010 | 06:40 PM
fordzilla01
Interesting... So, they aren't known to grenade then?
Old Nov 4, 2010 | 09:13 PM
rat49f6's Avatar
rat49f6
they can but not KNOWN for it
corey gernade'd one at around on around 500hp but its not common
Old Nov 5, 2010 | 12:19 AM
twags6's Avatar
twags6
Grabbed this out of an old thread https://www.ford-trucks.com/forums/3...t-for-zf6.html
The thread was from 2005, so present isn't exactly correct.
Originally Posted by n578md
I just got off the phone with ZF and here's what they told me:
The following years and engines use the "Standard Torque" version:
2002- present Ford 5.4L, and 6.8L
1999 - 2003 7.3L Diesel
2002 - present GM (6.0L) , 8.1L and 6.6L Diesel
All these transmissions have the same internal components minus input shaft differences for 4x2, 4x4, diesel/gas, bell patterns etc... which are rated at 520 Ft./Lbs.
The following uses the "High Torque" version:
2003 1/2 to present Ford 6.0L diesels that is rated at 570 Ft/Lbs.
The difference isn't in the actual component size or design but in the tooth cutting/finishing method used on the High Torque versions which yields a higher torque rating. So the gear set has a "smaller" torque rating on the Standard-Torque version than the gear set on the High-Torque version.
Your friend with the Duramax has the exact same internals as your 2005 V10, minus of course the ATF cooling pump and circuit. (GM doesn't use that feature.) You still have differences in bell patterns, which is integral on these units and you may have differences in input/output shaft dimensions too.
PS: As a matter of course, ZF does not recommend that you exceed 520 ft/lbs for the "standard-torque" S6-650 and 570 ft./lbs for the "high-torque" S6-650...
PS #2: You should have bought a diesel. Real men use diesel...
Old Nov 5, 2010 | 12:50 AM
fordzilla01
Well seeing as I am almost double that, its kinda scary... Hmmmm, so I should be thinking about a new tranny then?
Old Nov 5, 2010 | 05:47 AM
ron's power stroke's Avatar
ron's power stroke
there are a lot of guy's making a lot more power then what you have on a hand shaker and there still rolling along..i didnt see fuel mod's listed in your sig...spend your $$$ on a good full fuel system (tank to injectors then back to the tank) to keep them injectors alive...every time the PSI drops your loosing power and adding wear to the injectors..
XBAJBUSX
23
Oct 22, 2014 06:43 PM
okwaho1650
Mar 1, 2012 05:58 PM
rodneywar
15
Mar 3, 2011 09:17 AM
Moyerboy
6.4L Power Stroke Diesel
Oct 28, 2010 10:17 PM
