never mind i did a search and finally found what i was looking for i dont want to mod my floor pan at all!! anybody want a good auto set up in exchange for the zf5 set up
to be honest the zf6 is not worth the hassle like said above, you have to mod the floor pan to fit the taller bell housing and the gear ratios are near the exact same, so you dont gain anything just that one useless granny gear. just buy a zf5 and slam that it, direct fit.
actually, the gear ratio for a manual is lower so youll loose a few mph and gain rpms, an auto will blow away my zf in the rpm game all day long with the same gearing and tires.
cant be, people who have swapped from the zf5 to the zf6 did not notice a single difference in the OD, maybe a single mph. the difference between auto and manual is pretty large.
I've been big time on the fence about doing a ZF-5 swap in my rig. I too miss having a hand shaker, but I don't want to gain rpm/lose mpg when cruising since I do a fair bit of highway driving. But a built auto just costs so stinkin' much... What would be perfect is to find a Gear Vendor unit in a wrecking yard and put that behind the ZF-5.
Good luck with that. I think you'd have better luck finding a high-low rear.
