tire size change ??
Old Nov 4, 2010 | 12:22 PM
tdmiller1965's Avatar
tdmiller1965
tire size change ??
My truck came with 245/75/r-17 I just baught a set of 265/60/r-18. will this change my speedometer and mpg calculations ?
Old Nov 4, 2010 | 12:39 PM
machine62's Avatar
machine62
yes, your new tires are about an inch smaller in diameter. your speed will actually be about 3% slower than what the speedo reads.
Old Nov 4, 2010 | 12:46 PM
tdmiller1965
How can they be smaller if I went from 17's to 18's ????
Old Nov 4, 2010 | 12:52 PM
machine62's Avatar
machine62
The first number is the width in mm. The second # is the height of the sidewall as a % of the width. 75% of 245 mm is taller than 60% of 265 mm
Old Nov 4, 2010 | 12:57 PM
cartmanea's Avatar
cartmanea
Wheel size doesn't matter, tire size is what changes the speedometer accuracy.
Old Nov 4, 2010 | 12:59 PM
720Deere's Avatar
720Deere
You went to a wider tire but the aspect ratio is lower thus making the sidewall almost 2.5" shorter. Tirerack.com has some pretty good information on tire sizes and what they mean.
Old Nov 4, 2010 | 01:28 PM
djjoshuad's Avatar
djjoshuad
technically, the wheel size does matter some... in order to get the overall diameter of the tire, you have to include the diameter of the wheel, not just the height of the sidewall. Of course, you also have to include the tread depth (since that's not part of the sidewall measurement). It's usually best to get the "revolutions per mile" of each tire and see how far off you are. This info can usually be gotten from the manufacturers' websites
what brand and model were the old ones? and the new ones?
Old Nov 4, 2010 | 02:24 PM
tdmiller1965
old ones are Cooper "Grabber" new ones are Michelen. they came off of a 2011 f-250 FX4.
Old Nov 4, 2010 | 02:44 PM
Blown2run's Avatar
Blown2run
<TABLE cellSpacing=0 cellPadding=0 width=474 border=0><TBODY><TR><TD class=bodyText width=224>This might help.
What size is being run now?
<INPUT onkeyup="return autoTab(this, 3);" maxLength=3 size=4 value=245 name=origwidth>/ <INPUT onkeyup="return autoTab(this, 2);" maxLength=3 size=4 value=75 name=origratio>R- <INPUT onkeyup="return autoTab(this, 2);" maxLength=3 size=4 value=17 name=orim>
</TD><TD vAlign=bottom align=left width=25></TD><TD class=bodyText width=225>
What size would you like to run?
<INPUT onkeyup="return autoTab(this, 3);" maxLength=3 size=4 value=265 name=alterwidth>/ <INPUT onkeyup="return autoTab(this, 2);" maxLength=3 size=4 value=60 name=alterratio>R- <INPUT onkeyup="return autoTab(this, 2);" maxLength=3 size=4 value=18 name=arim>
</TD></TR><TR><TD width=474 colSpan=3 height=20></TD></TR><TR><TD width=474 colSpan=3><INPUT onclick=calculateSizes(this.form) type=button value=Specs/Compare name=boxChecker s_oidt="2" s_oid="functionanonymous(){calculateSizes(this.for m)}"></TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width=474 border=0><TBODY><TR><TD width=474 colSpan=4 height=20></TD></TR><TR><TD class=bodyText width=474 colSpan=4>Results</TD></TR><TR><TD class=bodyText width=150>Totals are in inches</TD><TD class=bodyText width=80>Tire 1</TD><TD class=bodyText width=80>Tire 2</TD><TD class=bodyText width=164>Difference</TD></TR><TR><TD class=bodyText width=150>Sidewall Height:</TD><TD width=80><INPUT size=7 value=7.23 name=OINSideWall></TD><TD width=80><INPUT size=7 value=6.26 name=AINSideWall></TD><TD width=164><INPUT size=7 value=-0.97 name=DIFFside></TD></TR><TR><TD class=bodyText width=150>Section Width:</TD><TD width=80><INPUT size=7 value=9.65 name=OINTireWidth></TD><TD width=80><INPUT size=7 value=10.43 name=AINTireWidth></TD><TD width=164><INPUT size=7 value=0.78 name=DIFFsect></TD></TR><TR><TD class=bodyText width=150>Overall Diameter:</TD><TD width=80><INPUT size=7 value=31.47 name=OINTireDia></TD><TD width=80><INPUT size=7 value=30.52 name=AINTireDia></TD><TD width=164><INPUT size=7 value=-0.95 name=DIFFdia></TD></TR><TR><TD class=bodyText width=150>Circumference:</TD><TD width=80><INPUT size=7 value=98.86 name=OINTireCir></TD><TD width=80><INPUT size=7 value=95.88 name=AINTireCir></TD><TD width=164><INPUT size=7 value=-2.98 name=DIFFcir></TD></TR><TR><TD class=bodyText width=150>Revs per mile:</TD><TD width=80><INPUT size=7 value=640.9 name=OREVMile></TD><TD width=80><INPUT size=7 value=660.82 name=AREVMile></TD><TD width=164><INPUT size=7 value=19.92 name=DIFFrev></TD></TR><TR><TD width=474 colSpan=4 height=15></TD></TR><TR><TD width=474 colSpan=4></TD></TR><TR><TD width=474 colSpan=4 height=15></TD></TR></TBODY></TABLE><TABLE cellSpacing=0 cellPadding=0 width=474 border=0><TBODY><TR><TD class=bodyText width=237>If your speedometer reads: <SELECT onchange=calculateSizes(this.form) name=ospeed> <OPTION value=20>20</OPTION> <OPTION value=25>25</OPTION> <OPTION value=30>30</OPTION> <OPTION value=35>35</OPTION> <OPTION value=40>40</OPTION> <OPTION value=45>45</OPTION> <OPTION value=50>50</OPTION> <OPTION value=55>55</OPTION> <OPTION value=60>60</OPTION> <OPTION value=65 selected>65</OPTION> <OPTION value=70>70</OPTION> <OPTION value=75>75</OPTION> <OPTION value=80>80</OPTION> <OPTION value=85>85</OPTION> <OPTION value=90>90</OPTION> <OPTION value=95>95</OPTION> <OPTION value=100>100</OPTION></SELECT></TD><TD class=bodyText width=237>You're going approximately: <INPUT size=5 value=63.04 name=ASPERead></TD></TR></TBODY></TABLE>
Old Nov 4, 2010 | 02:48 PM
Byram's Avatar
Byram
Mich 265/60R18 - 682 rev/mile
General Grabber - 245/75/17 - 662 Rev/Mile
I knop OP said Cooper - but only found general Grapper
djjoshuad's Avatar
djjoshuad
that's a great find for ballparking it. also keep in mind that really aggressive tires tend to have a much deeper tread than highway tires... so the revs per mile can vary significantly from model to model *even within the same size*. and of course, that changes with tire wear... your speedo isn't going to be 100% accurate no matter what you do. even straight from the factory
Old Nov 4, 2010 | 03:14 PM
tdmiller1965
Thanks guys. I don't yhink i will worry about 2 mph. again thanks, this forum always helps with my questions.
Imfubar
Dec 25, 2015 06:35 AM
PRyan1983
24
Sep 23, 2015 01:11 PM
emeraldcoupe
Jun 3, 2015 02:21 PM
SSBB
Jun 26, 2014 05:49 PM
351Cleveland C4
Mar 15, 2014 09:36 AM
