Sponsored by: Innova
back up camera is fogged up
Old Nov 4, 2010 | 01:32 AM
drakethegreat's Avatar
drakethegreat
I've got a 2010 F350 Lariat. One of the selling points for me was the back up camera. Last time I came back from a work trip the screen was obstructed and I couldn't see anything on it. I took a closer look at the camera expecting dust or ice and it had moisture internally that could not be wiped clean. Any one else have a problem like this or know of a solution. I live in Alaska and getting my truck back to the dealer can be a pain in the ***.
Old Nov 5, 2010 | 10:59 AM
bgalaxy67's Avatar
bgalaxy67
It is not very common but it can happen.
I would first try to disassemble it and try to clean the lenses and then reseal it as you put it back together.
If you get to the moisture before if affects the housing then it should be an easy process.
Old Nov 5, 2010 | 06:33 PM
macattack's Avatar
macattack
The camera should still be in warranty they are usually one year. They are not that hard to replace its mainly just a matter of rerunning the wires. Just make sure you replace it with a waterproof camera.
Old Nov 7, 2010 | 08:12 AM
TIKT B8's Avatar
TIKT B8
If it is an OEM camera on your Lariat, then it should still be under warranty and I would take it in and get them to replace it.
It is rare but it happens.
Old Nov 24, 2010 | 12:33 PM
Bryishre's Avatar
Bryishre
I drilled 2 very small holes in mine. fog went away and had no problems since
butch50
Jul 22, 2015 12:28 PM
SniperVision
Jun 5, 2013 08:01 PM
budhare
6.7L Power Stroke Diesel
Oct 27, 2012 09:43 AM
drakethegreat
6.4L Power Stroke Diesel
Nov 4, 2010 12:38 PM
adbscu
Mar 25, 2009 02:31 AM
