Offroad & 4x4
4.9L prerunner
Old Nov 15, 2010 | 03:01 PM
  #46
dirtdobberoffroad's Avatar
dirtdobberoffroad
see chase that is what I dont under stand the class 3, I suppose each class has restrictions on what you can do I just dont what class is what...guess I will look it up
Oh and what are some good magazines that I can get prerunner info in?
Old Nov 15, 2010 | 03:18 PM
  #47
ChaseTruck754's Avatar
ChaseTruck754
For the magazines - OFF-ROAD usually has some good dezert coverage and DirtSports is just plain bad arsed!
Here's a little more reading/learning for ya!
Desert Rides :: Desert Term Glossary
Old Nov 15, 2010 | 04:45 PM
  #48
dirtdobberoffroad
I guess we are not all that different.
Old Nov 15, 2010 | 04:51 PM
  #49
dirtdobberoffroad
Does any one know if the lift leaf springs on a 4x4 and a 2x4 are the same length and width... I would think they are but Im not 100%?
Thanks
Old Nov 15, 2010 | 04:56 PM
  #50
ChaseTruck754
Depending on the 4x4 they are 3" wide wheras I think all 2x4's are 2.5" wide.
Old Nov 16, 2010 | 11:41 AM
  #51
dirtdobberoffroad
Correct 2x4=2.5 and 4x4=3, dang I thought I found a set of 6" leafs for the rear but they are to wide....I dont have the truck where I can measure the spring hanger, I wonder if the 3" will fit?
Old Nov 16, 2010 | 11:51 AM
  #52
ChaseTruck754
you'd have to change out the hangers.
Old Nov 16, 2010 | 12:19 PM
  #53
dirtdobberoffroad
if I can get the springs cheap enough I might go junk yard diving......should be able to pick up a set cheap!
Old Nov 16, 2010 | 12:22 PM
  #54
ChaseTruck754
That might be worth while. the only problem with that is the time it takes to grind/cut/drill out the rivets.
Old Nov 16, 2010 | 01:34 PM
  #55
dirtdobberoffroad
Yeah that would take a while in a junk yard.
Does any one know if they make a set of bedsides for a long bed with two tanks.. I cant find any.
Old Nov 16, 2010 | 01:38 PM
  #56
ChaseTruck754
I think the fill doors are an option on most bedsides. Contact the maker and ask if they can add the duals. I bet they can.
Old Nov 17, 2010 | 02:11 PM
  #57
dirtdobberoffroad
That would be great if they could, I don't want to go as far as changing my tanks yet, but maybe a stock car fuel cell in the future
Old Nov 17, 2010 | 03:08 PM
  #58
dirtdobberoffroad
Found my set of fenders and bed sides, McNeil racing ( perrys fab&fiber), 6"front fenders for 300 and 4"bedsides for 600. Does any one know any thing about this company I have no idea, are the bed sides worth that?
Old Nov 17, 2010 | 03:10 PM
  #59
dirtdobberoffroad
Oh yeah and Chase I joined dezertrangers... if you are on there.
Old Nov 18, 2010 | 08:04 PM
  #60
dirtdobberoffroad
what size tube do you use for interior cage 1.75?
