Sponsored by: Real Truck
Feedback on Onboard Air System
Old Nov 2, 2010 | 10:57 PM
onug's Avatar
onug
I had Firestone airbags on my last truck. They worked great, but I don't need the bags this time around. What I do miss is the on-demand air system. The full-duty air system it came with was awesome for keeping my truck and my trailer's tires aired up at the right pressure.
So, I'm thinking of the Firestone system again, but I want other's inputs as well. I see ARB and Viair have systems available. I don't want to run airbags this time around, but I am going to plumb air to both the front and back of the truck. Full duty cycle is a must, but I don't necessarily want a large tank unless there's is room to mount it to the frame. I don't want to take up any bed space with some of the larger tanks I see online.
Tell me what you like, dislike and recommend...
Old Nov 3, 2010 | 12:22 PM
11350KINGRANCH's Avatar
11350KINGRANCH
I have the Viair constant duty system with a 2.5 gallon tank. Works great!!!
Old Nov 3, 2010 | 12:46 PM
onug's Avatar
onug
Where do you have the tank mounted?
Old Nov 3, 2010 | 07:39 PM
Fordfanatic4life's Avatar
Fordfanatic4life
i have the Firestone system with the onboard compressor and tank mounted to the inside of the drivers frame rail right under the rear door..
works awesome.. its so dam handy...
Old Nov 3, 2010 | 11:41 PM
c.f.moore's Avatar
c.f.moore
I have a couple of Viair pumps mounted under the right side of the cab, outside the frame rail. I have a 5 gal tank mounted outside the frame on the right side just ahead of the right rear tire. Lots of room for accessories under the cab and box. Out of sight and out of mind.
Good luck
Old Nov 4, 2010 | 04:22 PM
RedNNBlue's Avatar
RedNNBlue
I'm gathering parts together and will begin the install of my onboard system, most likely, this coming week. I have a viar 350c compressor (rated at 100% duty cycle) which will be mounted behind the rear seat and a 5 gal tank mounted outside on the pass side frame rail, just behind the cab. I'll post pics as soon as I can.
caere
6.7L Power Stroke Diesel
Apr 25, 2020 12:40 PM
Lonzom10
6.4L Power Stroke Diesel
Mar 22, 2015 06:32 PM
airjeff
Mar 6, 2011 04:47 PM
glsurratt
Apr 19, 2009 05:06 PM
mrxlh
Nov 19, 2006 11:15 PM
