Is this normal?
Old Nov 2, 2010 | 09:41 PM
myklstrng's Avatar
myklstrng
Is this normal?
I installed a used harness from the junkyard in my 73 hiboy. I noticed when I rev the motor the cab light gets brighter. Is this normal?
Old Nov 2, 2010 | 09:47 PM
dogmantra's Avatar
dogmantra
Probably not. I mean, no. But mine does that, too.
Old Nov 2, 2010 | 10:33 PM
eviiltim72's Avatar
eviiltim72
Was the junkyard harness out of the same year truck. I put the wrong year harness in a truck once and the gauge would flutter, don't know about the cab light since I never got around to fixing that. I added a quote from NumberDummy showing the different harness.
D8TZ14305A .. Alternator Wiring Harness / Use with 70 amp Alternator / Use with Oil & Amp Warning (idiot) Lights / Obsolete
D8TZ14305B .. Alternator Wiring Harness / Use with 70 amp Alternator / Use with Oil & Amp Gauges / Obsolete
D8TZ14305C .. Alternator Wiring Harness / Use with 40/60 amp Alternator / Use with Oil & Amp Warning (idiot) Lights / Obsolete
D8TZ14305D .. Alternator Wiring Harness / Use with 40/60 amp Alternator / Use with Oil & Amp Gauges / Obsolete
All fit: 1978 F100/350 I-6 or V8 / D8TZ14305C & D also fit 1978 Bronco.
Old Nov 2, 2010 | 10:57 PM
myklstrng's Avatar
myklstrng
Yes it was the same year 73-75 only 2 major differences of the junk truck was it had an automatic and a/c
Old Nov 2, 2010 | 11:01 PM
Furyus1's Avatar
Furyus1
Several factors to consider - age of harness and condition of wire; flaky ground somewhere; alternator output; etc...
Anything else except the cab light affected?
Old Nov 3, 2010 | 06:36 AM
myklstrng's Avatar
myklstrng
Not sure if anything else is affected, since my carb is preventing me from actually driving the truck.
gappy
Nov 10, 2008 03:03 PM
Chance_Thomas
26
May 6, 2008 12:32 PM
99EdeBauer
18
Feb 2, 2008 11:57 AM
QFD90
Aug 4, 2006 01:19 PM
cliffordthetruck
Mar 5, 2004 06:44 PM
