using cardboard to block radiator
any of you guys using cardboard to block your radiators if so how much? and where you putting it at?
my wife commutes 4 miles each way to work at 40 mph and i would like it to warm up better for her in the winter, but dont want it to over heat of course.. we are in alaska and its usually 0-10F but gets around -20f for about a week or so in january, right now its been high 20s at night.
I also have about a 4 mile drive to work, and if I don't plug the truck in at night when it gets down to the single digits, I have no heat on the way to work. I say plug it in at night, then let it run about 5 to 10 minutes in the morning before she leave for work and she should have plenty of heat.
Cardboard won't help with that short of I drive. IMO
she has top of the line remote start, runs in drive 10 minutes before she leaves on her 5 minute commute.
From what I’ve experienced at those temps, a 20 min. drive at 50 mph it is just getting warm. What I do because I only have a 1.5 mile drive, I'll take an extra long loop around town to go to work and back just to get the oil warm and I also change my synthetic oil every 5000 mile because start-short run-stop action.
Agreed, my wife has that option, my trucks too long, o well.. b-uno, I forgot, your in the far North, it helps considerably down here. I can tell you, I drive big trucks and in the past had front covers like the guys mentioned but for that short of a drive, your stuck unless the wife takes a longer ride, IMO.
We don't get that cold down here most of the time, but when cold weather does arrive I plug my truck in with the block heater on a timer that comes on about 2-3 hours before I usually leave. I have it set to shut off about an hour after I normally leave so that if I don't use the truck the block heater doesn't run all day long.
I got one from a hardware store that will handle about 1200 watts or more.
