Neil, I have in-laws in La Plata. Nice enough town, but that part of the country just seems a little more prone to crime. One more reason I'm glad to have escaped.
I think I'll do the hose clamp thing mainly for when we travel. I have a fifth-wheel gate, but wouldn't want to loose it either.
First time my tailgate got stolen (previous truck) I cut a piece of stainless tubing that had an ID just a hair bigger then the mount. Installed that and never had an issue again. I've actually seen it ever so slightly ovaled not long after installing it from someone trying to steal it a second time.
First, the black casing is some form of plastic, not metal. Second, it is just an expensive hose clamp that requires a special key to move the worm drive screw as opposed to a screwdriver or 5/16 socket. At $16.00+, I guess it is worth it if your tailgate is never stolen but for those of you that have the ability to modify the worm drive screw of a hose clamp to use a special key or method for loosening, you do the math.
Simpler and cheaper solution. Costs under $2. Just use a small heater hose clamp. Open the tailgate, unscrew the clamp, wrap it around the right bottom hinge and screw it back together. Just make absolutely sure that when you close the tailgate, the screw is facing straight up. Keep your tailgate and cap locked.
