Thanks hope They still care them can"t find any here at home in Canada.LOL were behind being born eh lol Bush
You can order on line at DIESELSITE.COM or Call Bob Riley at 888 414 3457
What I liked about their kit was the fact that all necessary fittings, hose shutoff valves etc are included. No running around trying to find bits and pieces. Took me about an hour to install with minimal loss of coolant.
Well ordered the kit with a extra filter and the SSvalves also.Now the wait for UPS....Thanks every one for the help and coments...Bush
There is more to DIESEL coolant filters than catching up the dirt. The real filter also have SCA chemicals in it, that slowly dissolve over the time to replenish lost balance. Even Powerstrokes don't require SCA testing after filling up with balanced coolant, it doesn't hurt to have it balanced to prevent engine cavitation.
I do own Detroit diesel as well, that with wet sleeves require SCA balancing, so for about $60 I bought the same housing and element for my Ford 7.3 diesel. Probably overkill for the engine with 200k at the time, but I sleep better
You absolutely do not ever want to use SCA charged filters in the Powerstroke. They release way too much SCA into the coolant. They are designed for Class 8 sized engines.
Using Motorcraft Gold, or some people are now using ELC Organic Acid Technology coolants, with proper regular testing, is the only way to do it right.
Read the warnings about SCA charged filters on the DieselSite Coolant Filter page.
Thanks Chambers. I've always wondered about the need for coolant filters too. Since I have a 7.3, no EGR cooler, and over 100K miles, I'm banking on it being unnecessary.
There's been a number of posters in the 7.3 forum who had abrasives in the coolant wear through the engine front cover behind the water pump, filling the crankcase with coolant and wiping out their main bearings.
Make sure you bank enough money for a engine rebuild on it being unnecessary.
Thanks Bob and all the other Guys for the come backs I got the system on and running first time to do a job like that but the 62 year body told Me it was sore the same night lol I am glad I had the ideas of all You guys rolled into one sure helped Thanks again The vice grips to hold the hose as I operated as a Doctor would cutting the heater hose was a great idea lost about 3oz that was all..Now the wait to change the filter and cut open the old one see what is inside... I pre-filled the filter with Gold also... any way Take care I am installing a Remote start on My Honda 3000is generater now a job that will make camping nicer not running out side to start the gen.or shuteing it down before bed.... wish I had some advice for this job ...lol...Bushcheers from Canada!
Reason: spelling
