1978 351m missing
Old Oct 30, 2010 | 10:58 PM
Hsbrder01's Avatar
Hsbrder01
1978 351m missing
so i have ran into a problem with my motor and i'm wondering if anyone can help PLEASE! to get the motor to idle decent even with the miss the timing is 50 degrees advanced and when i bring it down it chugs and dies once you get below 30 degrees any ideas what this might be?
Old Oct 31, 2010 | 11:20 AM
ctubutis's Avatar
ctubutis
Distributor off by a tooth? Jumped timing chain? The numbers you're giving are WAY out
of range....
Old Nov 1, 2010 | 02:40 AM
Hsbrder01's Avatar
Hsbrder01
i think i may have it figured out but i will know for sure in the morning. i found a broken valve spring i can't believe i didn't see it when i had the motor aprt
Old Nov 2, 2010 | 10:48 AM
mark a.'s Avatar
mark a.
Are you checking the timing with the vacuum advance hose removed and plugged ?
superman79
Apr 26, 2025 01:12 PM
BkoBoss351
Oct 26, 2015 12:18 PM
endobear
Mar 16, 2015 02:36 PM
ithaca1230
Feb 28, 2015 10:36 AM
ithaca1230
Jun 16, 2014 08:15 AM
