With the introduction of the PTO, has anyone compiled a list of available PTO accessory manufacturers and accessories available for the 6.7L? I did a search in the forums and was not able to locate any information.
My truck is on order and I plan on using it for snow plowing and was curious what was available in the way of plows, spreaders etc.
I was a bit surprised that there is not much out there on what can be attached to the new Ford PTO. I know other applications exist (like winches, air compressors, etc.), just none of them seem to reference Ford specifically. Maybe it will take some time for the aftermarket guys to catch up, but I would think there is a viable market and someone would be catering to it.
i think the best policy if you find an accessory to run off the PTO is contact the manufacturer, their web site may not have updated information for the 2011 MY.
The PTO option has been around, Live Drive, not using the torque convertor is new for 2011. Here is a link to Muncie Power Products
Automatic Transmission with Live Drive
Capability (6.7L speed transmission only)
• Mobile and Stationary mode operation
are supported.
• Stationary mode operates in Park at
elevated engine speed. The maximum
load at the transmission PTO gear is 250
ft-lbs.
• The maximum load allowable for mobile
mode is 150 ft-lbs at the transmission
PTO gear.
PTO Gear
• Split shaft PTO compatibility on F-450/
F-550 Chassis Cabs with 6.7L Diesel
• Operates at a range of 700 rpm – 3000 rpm
• Vehicle calibration/ software standard on all
