Okay, Need Some Timing Advice (Please)
Old Oct 28, 2010 | 07:33 PM
FlyCool5.0's Avatar
FlyCool5.0
Question Okay, Need Some Timing Advice (Please)
I installed the msd 6A on the 1995 f150 with a 302. What does my timing need to be on the truck? My buddy set it initially, but under full power I hear what sounds like a "pinging" at around 3500RPM. Does this indicate that too much fuel is being inject or too little at the right time? Any info please. THANKS!!
Old Oct 28, 2010 | 11:09 PM
Conanski's Avatar
Conanski
Factory timing spec is 10deg btdc, be sure to remove the spout plug to disable conputer advance when setting it.
Old Oct 29, 2010 | 03:49 AM
TexasGuy001's Avatar
TexasGuy001
He is correct. Factory timing is 10 degrees BTDC. Definitely unplug the SPOUT. You can usually advance it a little to about 12 or so with out problems. I hope you realize that the MSD box is not going to gain you much of anything.
Old Oct 29, 2010 | 04:46 AM
lew52's Avatar
lew52
Same as above , but now that you have the 6A box , you could get the MSD timing controler so you can adjust the timing with the turn of a **** from inside the cab of the truck 130 bucks ....Lew
Old Oct 29, 2010 | 05:48 AM
TexasGuy001
I like that idea Lew.
Old Oct 29, 2010 | 08:19 AM
FlyCool5.0's Avatar
FlyCool5.0
Thanks Guys. I Wasnt Expecting A Gain Of An Sort. Got The Box For Free So I Figured Why Not. What Does The Pinging Noise Under Full Throttle Indicate. Too Much Fuel Or Too Little? When I Turn The Distributor Counter Clockwise the pinging get less and less.
Old Oct 29, 2010 | 08:23 AM
heidifleiss's Avatar
heidifleiss
I hate to hijack this thread but I'm sort of in a rush and can't figure out how to open a new post, so I apologize in advance.
I have a 1995 ford f350 xl 5.8
I desperately need the part# for the under hood engine wiring harness, mine is all burnt up and I called the dealer and no luck. And does anyone know where I can find one?
Can someone please help me out.
Any help is greatly appreciated.
Thanks!
Old Oct 29, 2010 | 08:31 AM
rla2005's Avatar
rla2005
Pinging at full throttle could be caused by too little fuel, carbon build up, low octane fuel or too much base timing. Anyone or combination of those items can result in pinging.
Old Oct 29, 2010 | 08:36 AM
rla2005's Avatar
rla2005
Thanks!
You are hijacking this thread. There is no complete wiring harness available from Ford anymore. You will need to source a harness from a salvage yard.
To create a new thread of your own look for the "New Thread" button near the upper left hand corner of the forum.
Old Oct 29, 2010 | 09:31 AM
FlyCool5.0's Avatar
FlyCool5.0
In This Case I Probably Have It Advanced Too Far. I Will Undo The Spout, & Plug In The Timing Light. Is It Really Necessary To Run 93 Octane With The MSD 6A Ignition System?
Old Oct 29, 2010 | 10:38 AM
lew52's Avatar
lew52
.....It works good for me , i use it with a 6AL box so i can change the timing with i spray nitous , then turn it up again when im not , with ever opening the hood ....Lew
Old Oct 30, 2010 | 06:35 AM
TexasGuy001
Who said you had to run premium fuel with the MSD ignition? You shouldn't have to do that. I will say that mine has always run better with mid grade.
Old Oct 30, 2010 | 06:36 AM
TexasGuy001
Thats pretty slick.
FordNFishinLover
1983 - 2012 Ranger & B-Series
Sep 27, 2018 08:49 PM
zus009
Sep 22, 2014 07:51 PM
justaboutbroke
15
Mar 4, 2014 09:17 PM
itsjustagreat1
15
May 11, 2009 01:32 PM
teflon_80
1978 - 1996 Big Bronco
16
Jan 16, 2003 08:20 AM
