I've been dealing with this harsh shift engagement problem for quite some time. I tested sensors, checked fluid, pulled codes and got nothing, im getting to the point where im just going to buy another transmission that i found for cheap, however I'm not sure wether or not its going to work because I have a 94 F150 with an E4OD, and the trans I'm looking at is out of a 93 f250 with an E4OD. Its the same transmission, however im not sure if the bellhousing is going to match up with my 302. Anyone know anything? The diesel's engine is a 7.3L IDI
Good question. The 5speeds are but i dont know about the autos
That's why I asked I did learn that while shopping, digging, looking for a ZF. I would think with the different torque / RPM ranges gasser Vs Diesel they would be but I do not know for sure.
not sure if this will help You might have to do a bit of reading
Hey yall im looking at ATS E4OD Stage 3 Package, 1995-98 Ford 4wd i understand that this is mainly a diesel company, but does anyone know if they offer this tranny in 351w bell housing bolt pattern it looks like a amazing tranny...... i just need a E4od tranny that will handle around 700 hp and 650 TQ .
I have several ford 5-spds this is my first auto !!! So far i hate it .. okay it's a 1993 E-350 460(7.5L) with a E40D in it ... what years will work to swap out? what motors will interchange ? did ford offer a 5-spd for E seires trucks? please any help will do thanks
i just had a company named gearstar build me my tranny and i love it. from start to finish the whole build for a level 4 Tranny build was about 4000 dollars and that included the standalone computer for the e4od from compushift...... plus the tranny has a 3 year 36000 mile warranty on it you really cant beat it the computer came with its own complete cut to length harness with plugs already on it making it a true plug and play system. the system also is complemented with a tps that hooks up to your carb if your running one like me. the same company aslo makes a nice bracket for tps mounting for a lokcar cable set up.........the set up is awesome ill put up pics later of computer system and all
