Can't find PCM...
Old Oct 28, 2010 | 05:02 PM
rolltide3006's Avatar
rolltide3006
Can't find PCM...
Just got my chip, and can't find the PCM in the cab . I see the thing under the hood, but I can't find the actual PCM in the cab. A pic would be awesome.
Old Oct 28, 2010 | 05:21 PM
Action4478's Avatar
Action4478
Here you go .Kudos to TJ ......Name:  user531986_pic45253_1283733810.jpg
It comes out from under the hood , you can see it behind the DS kick panel
Old Oct 28, 2010 | 05:22 PM
strokin'_tatsch's Avatar
strokin'_tatsch
Pull the kick panel off(trim that covers the E brake assembly), pull the E brake off(3 1/2" nuts) and slide it out of the way. You can see the PCM behind there barely. You need to pull the PCM out and clean the contacts for the chip though so you have to pull it from under the hood.
Old Oct 28, 2010 | 05:59 PM
rolltide3006
so Strokin you're saying that I shouldn't have to do anything in the cab? I see what you guys are saying about pulling it out from under the hood, but I can't get the thing over the finder well.
Old Oct 28, 2010 | 06:06 PM
superduty4x4's Avatar
superduty4x4
You have to pull a few bolts out of the fender liner and pull it back to get the PCM out.
Old Oct 28, 2010 | 06:10 PM
bad12jr's Avatar
bad12jr
Take the inner fender loose. Then get someone to pry it down and pull the pcm out. Take it apart and clean the contacts per the instructions. If you ever need to pull the chip after its easier done inside the cab. The ebrake bracket is only three bolts to change the chip.
Chase you clicked faster
Old Oct 28, 2010 | 06:30 PM
Action4478's Avatar
Action4478
If you have a dial (position selector) with the chip , you will need to install it from inside the truck ...
Old Oct 28, 2010 | 06:55 PM
rolltide3006
got it. I wedged a small crow bar in between the hood and the finder then closed the hood and it pushed the finder down. Had to give it a tap from inside and she popped out. Hopefully I can get my chip installed tonight.
Old Oct 28, 2010 | 10:48 PM
fordpride's Avatar
fordpride
how did the install go
jimjokjv
17
Jun 21, 2017 11:11 PM
sinapu
Mar 20, 2017 06:01 PM
zsterr
22
Jan 7, 2017 09:26 PM
Joe.s
1997 - 2003 F150
Sep 11, 2016 11:25 AM
chintonmd
35
Sep 20, 2012 11:26 PM
