Sponsored by: Real Truck
Door Panel clips..
Old Oct 27, 2010 | 08:27 PM
IHMANKY's Avatar
IHMANKY
Door Panel clips..
Driver's side door panel is really loose, so going to remove this weekend and fix the issue. Are the clips the standard discs with the ribbed posts on them that push through and lock or are they different? Wanting to buy a bunch of them before I start taking the panel off.
Old Oct 27, 2010 | 08:37 PM
2002 F350V10's Avatar
2002 F350V10
No
Ford truck door panels use a couple phillips screws which once removed , allow the door panel to lift up to remove. The "clips" that hook onto the door frame are actually molded to the back side of the door panel. If those are broken off from someone not in the know prying on the door panel, you would need to replace the entire door panel.
Old Oct 27, 2010 | 09:50 PM
IHMANKY's Avatar
IHMANKY
Well ain't that just a fine how-do-you-do! Thanks a bunch, will check that out.
Old Oct 27, 2010 | 10:50 PM
6.0freak's Avatar
6.0freak
I've got an 03' and there was one screw behind the light on the door panel and the other was behind the power window & lock switch plate
Old Oct 28, 2010 | 11:37 AM
Rick03F250's Avatar
Rick03F250
Replace??? ha ha
self tapping body screws work just as good.
ubereal2
Jul 21, 2016 03:33 PM
Broken40
Jul 2, 2016 05:03 PM
Riskit
Mar 14, 2016 08:18 AM
daveengelson
Feb 16, 2016 10:35 AM
ErrorS
Jan 11, 2005 10:47 AM
