Sponsored by: Real Truck
Super Duty gas problem
Old Oct 24, 2010 | 06:02 PM
Fordhead68's Avatar
Fordhead68
Ok I have a new to me 2000 SD 5.4 work truck with 60k miles. I have had to put 4 fuel filters on it since Jan.The gas poured out of the filter is thick and brown. Pulled the tank off to see if it was dirty. No it was clean as could be. What is causing the fuel filters to stop up. Is it the rubber fuel lines going bad or what?
Old Oct 24, 2010 | 10:54 PM
Fordfanatic4life's Avatar
Fordfanatic4life
pull the rubber fuel line and replace it ???
might be worth your time to slice it open and have a looksee inside it.
easy to replace..
Old Oct 25, 2010 | 10:39 AM
BareBones's Avatar
BareBones
Its possible that the previous owner may have done some fuel line work and not used fuel grade rubber line because it is more expensive. A non-fuel rubber hose will swell up and even disintegrate after a few months exposure to gasoline. So I'd be sure any rubber lines are marked for fuel, or at least that they don't appear to be "puffy".
Old Oct 25, 2010 | 11:50 AM
redford's Avatar
redford
FTE Leadership Emeritus
Did you drop the tank and empty it?
Old Oct 25, 2010 | 03:10 PM
bohiaa's Avatar
bohiaa
WOW. I would be interested in that filter inside the tank too. of corse if it's the lines it would NOT have reached it.
Best of luck 2 u
Old Oct 28, 2010 | 11:40 AM
Fordhead68's Avatar
Fordhead68
Yes, dropped the tank and drained it. Suprisingly clean.
bho
Dec 14, 2012 07:03 AM
gamaliel
Nov 9, 2012 12:00 PM
FordRun
Mar 27, 2012 06:38 AM
Primosf150
Dec 5, 2011 07:53 PM
dieselbogging
Dec 12, 2006 11:32 PM
