4X4 Low doesn't engage.
Old Oct 27, 2010 | 12:31 PM
edwardlloyd's Avatar
edwardlloyd
Anyone know where I should start looking. I'm pressing the brake pedal down and in neutral (automatic) and the 4X4 low doesn't engage, it just stays in Hi.
2005 5.4 8200lbs
Cheers
Ed
Old Oct 27, 2010 | 01:05 PM
bridge's Avatar
bridge
Sick 'n Tired
Have you tried letting the rig move forward a few feet, sometimes it doesn't engage unless you let it move a bit. If that doesn't work, get a big hammer and whack the transfercase motor.
Old Oct 27, 2010 | 07:15 PM
ruli00's Avatar
ruli00
same thing happened to me,
This fixed it
put it in 4x4 hi drive around 5 to 10mph, pop it in Neutral then to 4x4 lo.
Do not use the brake.
-ruli00
Old Oct 28, 2010 | 02:47 PM
edwardlloyd
All sounds a bit Model-T Ford eh!
Thanks guys. I'll try that.
Old Oct 28, 2010 | 02:57 PM
Coskid's Avatar
Coskid
Well most people never use the 4x4low or even 4x4 most likely so it tends to jam some and have more issues engaging. Use it once a month like the rest of your 4x4 system and the better it will work when you need it.
Old Oct 28, 2010 | 03:59 PM
danorules's Avatar
danorules
if there is a load on the drive shaft the transfer case will not engage the 4x4 low.that goes for most transfer cases. ideally you want to put it in nuetral, let off the brake enough to roll 2 feet, then engage 4x4 low. should go in no problem
countryboy1
Feb 2, 2008 10:53 AM
bigtim1985
1983 - 2012 Ranger & B-Series
Feb 16, 2007 07:15 PM
greek271
Jan 8, 2006 06:29 AM
ebraunusa
Dec 16, 2005 09:02 AM
ebraunusa
Feb 3, 2005 08:26 PM
