Leveling kit/tires installed, no time for alignment, problem?
Old Oct 26, 2010 | 07:56 PM
rvx290's Avatar
rvx290
Exclamation Leveling kit/tires installed, no time for alignment, problem?
(sorry couldnt think of a proper title for this thread.)
I just got my 2.5" leveling kit in and a new set of tires on, I drive a company truck during the week, so I dont put miles on my own truck. My truck is scheduled for an alignment for next week, but as my luck would have it I have a funeral to go to the day after tomorrow.
The funeral is 150 miles away, the conditions are cold, sloppy & snowy so I would rather take my truck with 4x4 & A/T tires rather than our car (with balding tires)
IF I AM going to cause noticable damage to my trucks new tires driving it the 300miles with the leveling kit intalled without an alignment, I will not take it.
.....am I going to do noticable damage to these tires?, or will 300 miles not make any noticable difference as long as I get the alignment without driving any futher than that?
(no I dont have time to do the alignment tomorrow, & no I cannot take the company truck to the funeral.)
Old Oct 26, 2010 | 08:02 PM
bridge's Avatar
bridge
Sick 'n Tired
Which tires? Actually, regardless of brand I wouldn't drive 300+ miles without the alignment. Depending on your proximity to a large city, most any place should be able to get it done in a few hours. NTB, Sears, etc...
Old Oct 26, 2010 | 08:04 PM
MCDavis's Avatar
MCDavis
It is really difficult to say what the extent of the tire wear will be during that 300 mile trip. Each truck responds differently to the leveling kit. You're likely to need a toe and caster adjustment. You'll likely to wear the outside edge faster.
If the adjustments needed are minimal, then you probably won't even notice the wear.
One user just reported that he had a out of balance type of wobble at speed, and after the alignment it was all good.
What would I do? Well since new tires, assuming you mess them up, will run you at least $300 for the pair (most likely more)...I'd rent a vehicle for the day and drive that to funeral. A Grand Cherokee or something of similar size should cost you no more than $150 with unlimited mileage.
That's just my $.02
Plus if you run off the road in a rental, who cares?
Old Oct 26, 2010 | 08:31 PM
1bad67sbf's Avatar
1bad67sbf
dont drive it anywhere but to get the alignment done. a guy on here put a level and wheels and tires on and took it for a test drive w/o alignment done and he said it made the truck shake bad, and that would suck for a 300 mile ride and could break something at highway speeds
Old Oct 26, 2010 | 08:32 PM
rvx290's Avatar
rvx290
(the tires are Cooper Discoverer S/T) thanks for the help, I also factored in that its cold & highways are slick, (slick meaning somewhat less wear, but maybe thats just my brain thinking in panic/despration mode.) If it makes any difference the truck had an alignment about 2 weeks before the leveling kit was installed (the leveling kit wasnt really planned, it was a whim, drinkin,trade lol.) & the truck does ride the same as it did before I put the tires & leveling kit on, but like I said the plan was to get the aligment done seeing as I havent put more than 10 miles on it since the installations. ...but so far its looking like the truck is going to have to stay put til I get that alignment unless someone else comes up with any convincing evidence to not worry about it.
Old Oct 27, 2010 | 05:40 AM
svt2205's Avatar
svt2205
Driving your truck with the toe off a bit will only wear your tires a little. Add the wet/slick conditions and that wear factor will be reduced. In 300 miles you're not going to wear enough of the tire for it to matter.
Paying respects to the indivudual who passed is more important then the minimal tire wear you might see.
Old Oct 27, 2010 | 08:11 AM
rvx290's Avatar
rvx290
point taken, (however I would be going to the funeral no matter what someway some how, turns out a local friend is going and offered a ride so that part of it worked out) however good to know incase somebody gets put in the same situation as me, its a good lesson on why to not procrastinate.
Old Oct 27, 2010 | 08:14 AM
MCDavis's Avatar
MCDavis
Glad to hear you're getting there safely to pay proper respects. Have a safe trip!
Old Oct 27, 2010 | 08:16 AM
Coskid's Avatar
Coskid
It is really a judgment call and every truck will be different. Some times when you install everything it can wait for the alignment but its not recommended. I agree with SVT that the wear will be minimal and that paying your respect to the dead is more important but just don't be surprised if you develop a bad shake during the trip.
Old Oct 27, 2010 | 04:22 PM
1bad67sbf's Avatar
1bad67sbf
its not the wear factor thats the problem its the fact that the truck would be unsafe to drive that far and it will put stress on steering parts for 300 miles and if a tie rod breaks at 80 he could be killed himself. glad to hear you got a better way to get to it.
Old Oct 28, 2010 | 03:35 AM
svt2205's Avatar
svt2205
Sorry, but the increase in toe to roughly 1 degree toe out, will not create an unsafe condition. It will not break steering or suspension parts. It will make the steering feel a little different, turn in response a bit quicker while adding a little bit of a darty type feeling. But hey, if you feel that this is an unsafe condition, that's cool.
Old Oct 28, 2010 | 05:23 PM
1bad67sbf's Avatar
1bad67sbf
yeah its called oversteer and people have drove after a level kit and had bad vibrations from the tires trying to driving toward themselves not just oversteer. but its all good i understand its up to that person.
Old Oct 30, 2010 | 08:59 AM
msgross's Avatar
msgross
My toe in was 1/2" off after my level kit. I couldn't get the truck over 40mph without it shaking... not sure what you ended up doing but you shouldn't do the install until you have an alignment setup for the next business day. Your money in the end though...
PapaBearYuma
May 13, 2017 01:00 PM
krys4990
2004 - 2008 F150
Nov 30, 2016 07:16 AM
highendredneck
New Member Introductions
Nov 17, 2015 10:43 AM
tooldad
2004 - 2008 F150
Jan 20, 2012 02:28 PM
jeffdoerr
18
Apr 4, 2007 02:48 PM
