what are normal iat temps?
Old Oct 26, 2010 | 11:10 AM
adisont's Avatar
adisont
just curious, i'm seeing around 130f in about 65f weather. i've got a dashhawk to watch some temps and this seem to be higher than what i was expecting.
Old Oct 26, 2010 | 11:14 AM
woodlander's Avatar
woodlander
On my Edge Insight, they are usually what the outside temp is at startup.
Old Oct 26, 2010 | 11:56 AM
npccpartsman's Avatar
npccpartsman
There are two IAT temps so make sure you are reading IAT1 and not IAT2 . IAT1 should be fairly close to outside air temp. IAT2 is higher since it's reading inside the intake manifold.
Old Oct 27, 2010 | 08:53 AM
adisont's Avatar
adisont
i was trying to get a grasp on what the iat2 temps are on average.
Old Oct 28, 2010 | 06:47 PM
HeavyAssault's Avatar
HeavyAssault
I run a 25*F spread between IAT1/2 while using a Spearco IC.
Old Oct 28, 2010 | 06:55 PM
cheezit's Avatar
cheezit
iat1 will be hotter by a few degrees prior to start up in most cases do to the maf heater element. but should be close to outside air temp.
iat will change and will be hoter then iat1 when running. the spread will very with egr flow. this is one of the ways the pcm can tell if the egr system is working.
andysam
Jul 13, 2016 07:38 PM
ironbender
6.7L Power Stroke Diesel
May 23, 2016 03:26 AM
Macs1964F100
Jun 5, 2014 09:18 AM
BryanStein
Jul 27, 2013 11:02 PM
sju96ford
19
Feb 22, 2012 09:54 PM
