Infrared Thermometer
Old Jun 4, 2014 | 06:25 PM
Macs1964F100's Avatar
Macs1964F100
I bough an infrared thermometer to see what my real water temp is. My question is where do you measure to determine the true water temp?
If all is working well then 190-210 degrees would be the correct temp. My long term goal is to replace the temp sensor if needed and adjust the stock gauge to read close to the center at 210.
Old Jun 4, 2014 | 08:30 PM
Macrobb's Avatar
Macrobb
I'm not sure. For one thing, if you're actually working the engine, you'll see it vary depending on location -- you shut the engine off after having just climbed a hill with a trailer, and latent heat will heat up the water inside the engine by a few degrees.
For another, infrared thermometers aren't perfectly accurate: » Point-and-shoot infrared random number generator How to Spot a Psychopath
Secondly, why not just get a proper digital water temp gauge? My Chinese one cost me around $30(inc sender and shipping); I replaced the second sender which controls the idiot light, and have a nice, responsive sender. Unlike with an analog(even a good one), it's nice seeing drops or gains of a couple of degrees -- Once you know what your temps usually are, you can spot a failing thermostat or other problem pretty quickly.
Old Jun 4, 2014 | 11:42 PM
Red454sedgwick's Avatar
Red454sedgwick
I go off the t-stat housing or close to it
Old Jun 5, 2014 | 06:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
i read off the area closest to the sensor if i can get it. otherwise, off the thermostat housing.
Old Jun 5, 2014 | 09:18 AM
Macs1964F100
Does your digital gauge have a warning light? I am not an idiot but I am fat, dumb and happy most of the time and like the security of warning light in addition to a gauge.
Oversize
Sep 21, 2009 09:20 PM
Oversize
Aug 11, 2009 09:32 PM
993/4ton
Modular V10 (6.8l)
Nov 12, 2006 12:27 PM
89broncobob
1978 - 1996 Big Bronco
Jul 6, 2003 07:08 PM
