Power window help / ideas
Old Oct 25, 2010 | 11:26 PM
aft2005exp's Avatar
aft2005exp
I have searched and read the different threads on slow power windows, but can't seem to find the answer to my question. I have a 2005 EXPY EB 4x4 103K miles and the power windows are starting to slow down both up and down. When two or more of the power windows are being operated they are even slower. Is it a relay issue, or motor problem? Any leads on where to start would be appreciated.
Old Oct 26, 2010 | 08:43 AM
alloro's Avatar
alloro
7 out of 10 times it's a motor issue, 2 out of 10 times it's the switch contacts deteriorating, and the last 1 out of 10 is due to corroded/failing electrical connections.
Old Oct 26, 2010 | 08:33 PM
aft2005exp's Avatar
aft2005exp
So 10 out 10 times, it come down to old fashion detective, testing and diagnostic work to get to the bottom of it. I will be starting all of the above hopefully this weekend!!
Old Oct 27, 2010 | 11:07 AM
dirtmonkey11's Avatar
dirtmonkey11
Sounds like the motors are getting bad, or there is a bad connection somewhere. You could try to lube the window regulator assembly to help with friction.
Old Oct 27, 2010 | 10:09 PM
aft2005exp's Avatar
aft2005exp
Thanks.. when I get into the doors, I will do that as well.. thanks !
Old Oct 28, 2010 | 10:39 AM
RedHorse1's Avatar
RedHorse1
Prior to one of the front window regulators failing the window was moving slower than normal. Then started making a grinding noise. Then it jammed up and I hadda put a new one in.
Let us know what you find.
Old Oct 28, 2010 | 08:04 PM
aft2005exp's Avatar
aft2005exp
Will do, I'm hoping my scraped knuckles will help some others figure it out easier.
Old Oct 29, 2010 | 09:46 AM
RedHorse1's Avatar
RedHorse1
back in 08 "yardbird" did an excellent write-up on replacing the regulator.
https://www.ford-trucks.com/forums/7...regulator.html
aft2005exp
Aug 18, 2011 02:22 PM
ramrod7373
Apr 19, 2011 08:40 AM
Zinfinity
Nov 27, 2008 06:10 PM
F150inOhio
1997 - 2003 F150
Jun 29, 2005 01:08 PM
odinmurphy
Jul 3, 2001 05:41 PM
