Battery tests good at store they'll say it just needs a charge, they say alternator is good, runs fine when jumped, just won't start on its own. Getting a ground reading from firewall to negative battery terminal.
Pulled starter off, has loose pinion gear and will be stopping at junk yard in the a.m.. Going to attempt to test ignition switch as well.
Any other ideas?
Grounds were clean.. even cleaned them again, I had gotten an ohm connection from negative terminal to firewall. Gives me same reaction if I jump the solenoid. New voltage regulator
Oh.. Starter had a bad pinion gear, replaced and still the same problem. I get 11.5 volts from battery when truck is on. I can drive anywhere however far.. just can't start it back up.
I can get it started with a jump. And I get 11.5v when the truck is running. But its kind of wierd, it seems like the battery will sometimes slowly climb to 11.8v (if i'm lucky) after the truck is off.
