90 2.3 running like crap
Old Oct 24, 2010 | 09:45 PM
diesel317's Avatar
diesel317
backwoods rednek
I have a 1990 ranger 4x4 2.3l. I changed the plug wires and plugs and now its running likes its misfiring. Rechecked all plugs and wires they are right and replaced coil pack on drivers side no change hooked new one up on pass. side no change changed fuel filter no change. put a vac. gauge on intake and reading 13psi with needle bounces alil oh and some blue smoke out the tail pipe.Good old truck dont want to junk it
Old Oct 25, 2010 | 01:14 PM
Bidwell's Avatar
Bidwell
So it ran better before the changes?
Old Oct 25, 2010 | 06:38 PM
KhanTyranitar's Avatar
KhanTyranitar
Ok, so it seems either one of the new parts is incorrectly installed, of has some other issue.
What brand parts did you use?
Old Oct 25, 2010 | 07:19 PM
V8Ranger302's Avatar
V8Ranger302
Did you check the gap on the new plugs before you put them in?
Old Oct 29, 2010 | 09:13 PM
diesel317's Avatar
diesel317
backwoods rednek
before i new tune up it ran fine but the wires were worn out i could hear the wires arching out i used motorcraft plugs and autolite wires all from advance auto parts i set the gap before install i know yall have to rule that out but not my first rodeo
Old Oct 30, 2010 | 04:28 AM
V8Ranger302
Sometimes even the best of us overlook the simple stuff, wasn't trying to say you didn't know what you where doing... Do you still have the old parts that you took off??? If you do, try putting them back in and see if it runs better. If it does, replace with the new parts one at a time till it runs like crap again...
Old Oct 30, 2010 | 11:14 AM
Bidwell's Avatar
Bidwell
If after changing plugs and wires with poor results, why did you keep changing parts? I think you "bumped" a plug changing the gap or possibly cracking it's insulator.
Old Oct 30, 2010 | 10:32 PM
diesel317's Avatar
diesel317
backwoods rednek
checked everything like 5 times and sorry the old parts got trashed cause they was bad i will put autolites in see how that does if not ill do wires agian
Old Nov 4, 2010 | 09:08 AM
diesel317's Avatar
diesel317
backwoods rednek
ok changed plugs from motorcraft to champs like the book called for have seen this type of problem in GM but still no change so will change wires next
