No reason you need a brand new carb. You have a 600 cfm carb which is just fine, just buy a rebuild kit and clean it up. All the while check what jets and needles you have and if needed purchase a Strip Kit which has jets, needles and needles and seats.
Josh
I have the same engine and carb and I was wondering what the OP asked too. My truck runs super rich and backfires too. I know everyone on here seems to say that a 600 cfm carb is too much for the engine, but a new carb is $300ish. Could I just buy a rebuild kit and put smaller jets in it? Im new to carbs.
That is a link to a calibration kit. If your plugs are showing rich you'll need smaller jets, bigger needles or both to tune the carb.
600 cfm is a more than enough for a 302, but not enough to warrant buying another carb. Esepcially considering the next size down is a 500 and the difference in performance would be negligible.
Josh
So I should rebuild the kit and also re jet it with smaller jets and or bigger needles?
The calibration kit comes with different sizes of needles and jets, so you'll need to play around until you find a combo that keeps the engine happy.
The thing to keep in mind is it's true the carb is 600 cfm, but it is likely 250 cfm primary and 350 cfm secondary, and most driving is done on the primary side.
