Carb too big for engine?
Old Oct 25, 2010 | 07:42 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You have different problems, but I believe they are all still carb related. The third gear problem could be combination of too big carb and secondaries opening too soon. Stalling at idle, idle circuit problems, hesitation off idle could be accelerator pump/squirters. First thing I'd do is pull it off and check out the RTV issue. Could have some where it doesn't belong. Regasket it properly. Since you have a 4V manifold a smaller 500-600 carb would be a good move if you wish to spend the money. You will have better throttle response for sure. Not going to advise between Holley and Edelbrock, I've had good and bad issues with both.
Old Oct 25, 2010 | 09:45 AM
LARIAT 85's Avatar
LARIAT 85
If the carburetor you have on it now has mechanical secondaries, that could be causing your problems. You will want a carburetor with vacuum secondaries.
I would like to make a better suggestion for a replacement carburetor...
Try to find a Motorcraft 4180 4V carburetor. They were found on '83-'85 Mustangs with the 5.0 and F150s/Broncos with the 351 H.O. motor. This carburetor will have all the emissions connections you will need, and with annular primaries, is a much better carburetor than either the Holley or Edelbrock.
Old Oct 25, 2010 | 10:02 AM
Muney's Avatar
Muney
Before I order a new carb, I need to find out what year engine I have. Please help me out and look here.
https://www.ford-trucks.com/forums/1...ml#post9476241
I was told it was an 87 302, but the plugs that fit it were used in the late 60s- early 70's 302s. I was told to count the bolts on the valve covers, and there are 5. Any help?
Old Oct 25, 2010 | 10:30 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Ford went to the the smaller 14mm plugs in 1975. Before that they were 18mm. If engine has been rebuilt, block casting code and heads could be different. No real way to tell without pulling the head to see it's casting number which is underneath next to intake manifold. Valve covers will have same bolt pattern till you get back to the 292-312 engine if I remember correctly.
Old Oct 25, 2010 | 10:35 AM
Old93junk's Avatar
Old93junk
True info.......once you find the casting no......PM a gentleman named Conanski, in the 87-96 F-series forum or in the small block V8 forum, he can ID the block very quickly, also... he is a fountain of knowledge on the 302 in general.
Old Oct 25, 2010 | 01:12 PM
Muney's Avatar
Muney
Found the cast number. 0 C5AE 6015E
Now i'll have to find this Conanski fellow.
EDIT: I just looked it up and apparently I have a 65 289 Hi-Po. So the dude that sold me this lied. Great. Is this engine any good?
Old Oct 25, 2010 | 02:36 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
A true 289 Hi-Po is rare. Look on the head in front of the valve cover. If the number is 19-20-21, they are Hi-Po heads. Worth a good bit of money to someone restoring a K code Mustang.
Old Oct 25, 2010 | 02:39 PM
Muney's Avatar
Muney
I will just assume that it isn't a hi-po. Next question. When looking for a carb or any parts for this engine, do I look for 289 specific? I heard the 289 is pretty much the same as a 302, just a different stroke. So would intake manifolds, carbs, headers for a 302 fit the 289 or net necessarily?
Thanks for the patience with my newb questions.
Old Oct 25, 2010 | 02:43 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Anything on the outside of the engine will work. All the more reason for a smaller carb. But check those numbers and the number on the intake if it's it still stock. Stranger things have happened, you might get lucky.
Old Oct 25, 2010 | 06:28 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
No reason you need a brand new carb. You have a 600 cfm carb which is just fine, just buy a rebuild kit and clean it up. All the while check what jets and needles you have and if needed purchase a Strip Kit which has jets, needles and needles and seats.
Josh
Old Oct 25, 2010 | 06:30 PM
Bullitt390's Avatar
Bullitt390
The Edelbrock Performer/ AFB is a vacuum secondary carb, which is what he has.
Josh
Old Oct 25, 2010 | 09:38 PM
Yacomash800's Avatar
Yacomash800
i have a 1983 460, headers, edelbrock performer intake, i mounted a edelbrock 750 cfm 4bbl and it runs great!
Old Oct 26, 2010 | 07:49 AM
  #28
Muney's Avatar
Muney
Yeah, but I have a 289, you have a 460.
Old Oct 26, 2010 | 08:02 AM
  #29
MAULMAUL's Avatar
MAULMAUL
Just a wee bit of difference isn't there? I have a Motorcraft 2150 on my 77' 302 and it runs great.
Old Oct 26, 2010 | 01:33 PM
  #30
Muney's Avatar
Muney
Josh
This is what I thought I could do, but by the sounds of it on here I should just get a new carb. I might try this first and find someone that can rebuild this thing for me since it's a lot cheaper than a brand new carb. Good or bad idea?
