My truck doesn't start
Old Oct 22, 2010 | 03:31 PM
Waffle17's Avatar
Waffle17
I turned the key in my truck today and I didn't get anything, no sound, no nothin. The electronics were working so I know it wasn't the battery.
Any ideas or suggestions and how much it would cost to repair or how easy it would be to repair.
p.s.
I had my truck warming up early this morning and when I got back in I turned the key again (forgeting that it was already started) and it made the grinding noise and I didn't think much of it cause everbody's done that, but it was the first time I've done it in my 92 F-150, I think.
I was wondering if maybe my starter was going bad and that pushed it over the edge, but my starter seemed fine before. It would only take a couple cranks and it fired up so I don't know.
Anything would be helpful.
Thanks
Old Oct 22, 2010 | 07:54 PM
C. McAuley's Avatar
C. McAuley
4wd High
If you can get a good look at the starter there’s is a braded wire that leads from the starter to starter motor. This Braded wire has a tendency to wear thin and burns like a fuse. The braded wire is a part of the brush *** I paid $10.00 at le local rebuilders shop. Check it out and let us know how ,it turns out have a good day.
Old Oct 22, 2010 | 08:51 PM
mikehawk's Avatar
mikehawk
Most parts stores will test your battery for free.
If the battery checks out ok you might want to take a look at your cables. I had a 91 explorer that had similar symptoms, dome light and radio worked, but nothing happened when I tried to start it. I peeled back the insulation on the negative cable and found green crusty wires.
Old Oct 22, 2010 | 09:57 PM
g_k50's Avatar
g_k50
Did you hear the fuel pump running?
Old Oct 22, 2010 | 10:03 PM
skyfox10's Avatar
skyfox10
if the truck started fine (fine for some is not fine for others) then it quit just like that and don't hear anything. I would suspect the starter relay on the inner fender.
If the battery was not great or if you had a bad connection, you should still hear this relay. No relay click, no good relay. Also, you can test this for free by jumping the terminals on the relay.
Old Oct 23, 2010 | 12:35 PM
Waffle17's Avatar
Waffle17
Wel I asked my friend about it and he said to just tap the starter with a wrench and sure enough it started. Then i had to the same thing later that night (tap the starter).
Anyone know what that might be?
Thanks guys.
Old Oct 23, 2010 | 01:57 PM
skyfox10's Avatar
skyfox10
it's the solenoid on the starter, I had that happen on my 95. I'd carry a hammer with you wherever you go, but it will continue to get worse. I'd replace that starter solenoid ASAP.
Old Oct 23, 2010 | 02:26 PM
Waffle17's Avatar
Waffle17
Alright I did a little research and that's what I was thinking it could be.
So I will get that done and let u guys know.
Thanks for your help.
Old Oct 23, 2010 | 04:13 PM
skyfox10's Avatar
skyfox10
Any time. Keep us posted
96halfton
May 28, 2018 01:38 PM
adamkat22
51
Sep 4, 2015 07:53 AM
dan6915
Jun 11, 2015 10:30 AM
websthes
Dec 7, 2010 08:09 PM
hunteradams7
22
Mar 15, 2009 09:36 PM
