Electrical Problem!!
Old Oct 22, 2010 | 08:45 AM
PoPo54's Avatar
PoPo54
99 F250 PSTD 4x4 7.3
Thanks for looking guys. Couple of days ago I started having start-up issues. Had to jump it and go that way. Thought it was the alternator but had it all tested and found out I had a bad battery. The truck was fine yesterday. I wake up today and my truck is dead. I noticed my brake lights were on even though my truck was off. Now I have no juice. My alternator? electrical issue? how do I narrow it down?
Old Oct 22, 2010 | 09:31 AM
thomabb's Avatar
thomabb
Look at the brake light switch on the pedal. Fix the brake light problem first.
Old Oct 25, 2010 | 12:33 PM
PoPo54's Avatar
PoPo54
so I perfomed a multimeter test between the a cable and the post on one of my batteries and the reeading showed a draw of 0.800 amps. pulled all fuses in the cab and under the hood one by one and left them off and disconnected alternator and still at 0.800 amps. no clue what to do next. put a trickle charger on my batter overnight last night and started right up this morning. sat for about 4 hours and I went to crank it and it was dead again. is there anything else that still draws when all fuses are pulled and alternator disconnected?
Old Oct 25, 2010 | 12:35 PM
PoPo54's Avatar
PoPo54
brake light
think the brake lights were intermittently coming on and off because my batteries were on their last wind. brak lights stay off when it is charged and running. thanks for the reply though. im stumped.
Old Oct 25, 2010 | 01:27 PM
thomabb's Avatar
thomabb
Weak batteries will not cause your brake lights to come on. It's the other way around.
I wish you luck. Electrical issues on these trucks can drive a man to drink.
(That reminds me, I have to stop for beer after work.)
Old Oct 25, 2010 | 01:38 PM
PoPo54's Avatar
PoPo54
HAHAAHA...THANKS FOR THE REPLY. I EVEN STUMPED THE ELECTRICAL TECH AT THE FORD DEALERSHIP
Old Oct 25, 2010 | 10:35 PM
PoPo54's Avatar
PoPo54
so i went out to my truck this evening and my driver side battery was real hot. not sure if it was from the draw or not. thoughts?
Old Oct 26, 2010 | 07:10 AM
thomabb's Avatar
thomabb
You possibly have a hot wire somewhere jumping to ground. It would be a big wire. Check the wire going to your starter for damage.
Old Oct 26, 2010 | 08:24 AM
Grubbworm's Avatar
Grubbworm
PoPo54,
I have some troubleshooting tests posted in an album, on my profile page.
Here's the link;
https://www.ford-trucks.com/forums/m...needs+it..html
Let me know if they help.
RKuhlman
Mar 25, 2013 08:40 PM
DeathSpiral
Jun 17, 2010 12:30 PM
DeathSpiral
May 6, 2010 11:13 AM
bigtexan99
28
Jul 20, 2009 12:13 PM
poulin15
Jan 30, 2003 08:30 AM
