Adding an overdrive unit
Old Oct 21, 2010 | 10:00 PM
Otahyoni's Avatar
Otahyoni
I found a Doug Nash overdrive unit here local for $150. Will it bolt up to my transfer case? I know i wouldn't be able to use 4x4 with it in OD.
If it won't bolt up, what do i need to do to run it divorced?
Old Oct 21, 2010 | 10:38 PM
LCAM-01XA's Avatar
LCAM-01XA
Actually IIRC with the Doug Nash (or US Gear, same thing) units you can use 4x4 with the unit in either gear, as it goes between the trans and the transfer case - it's the Gear Vendors units that cannot be used in 4x4 as they go behind the transfer case and so only change the gear ratio for the rear driveshaft. About fitment in the DNE unit to your setup I dunno, but at $150 I'd buy it anyways, then look for adapters and such on ebay if anything is needed.
Old Oct 21, 2010 | 11:37 PM
87crewdually's Avatar
87crewdually
Is the Nash O/D the one that goes between the engine and trans?
Old Oct 21, 2010 | 11:59 PM
LCAM-01XA's Avatar
LCAM-01XA
Nope, that's the Ranger, and it only works with stick-shifts that have non-integral bell housings, as it actually goes between the bell and the trans (so it would work for a T18/19, but not for a ZF5). The DNE and US Gear ones go between the trans and the transfer case.
Old Oct 22, 2010 | 06:53 AM
Otahyoni's Avatar
Otahyoni
Thanks a bunch LCAM! I'll pick it up this weekend then.
jayro88
23
Jul 5, 2014 11:39 PM
pm042070
Sep 25, 2013 12:55 PM
Ford79
Oct 20, 2008 02:53 PM
banjopicker66
May 22, 2004 07:54 PM
