injector oring install
Old Oct 21, 2010 | 09:44 PM
nookiemonster55's Avatar
nookiemonster55
Well, troubleshooting my excursion smoking and decided while in there to change the injector o rings. I know the injectors have been pulled at least twice and to my knowledge no new o rings were installed.
Question is this: I was looking at the little copper dooomah flangy and noticed one side was a tad bit raised and other recessed. Does it matter as to which side goes toward the cylinder or does it really matter?
Still stumped in Mississippi
Old Oct 21, 2010 | 11:45 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
No, you can install the copper washers either way, but make sure all the old ones came out of the heads and that all the new ones stay on when installing. Allow the new o-rings to shrink after install and lube injector with motor oil before insertion as well. Also, I recommend only using OEM orings from Alliant or Motorcraft. Probably telling you what you already know though.
Old Oct 21, 2010 | 11:48 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Are you talking about the copper washer on the nozzle? Here is a photo of what it looks like when it's on the injector. I thought the washers were asymmetrical and could be installed either side up. Maybe my kit was different than yours?
Old Oct 22, 2010 | 01:12 AM
nookiemonster55
thanks btw.. they are alliant brand...that little circle groove just looking closely at it one side is raised....just wanting to make sure...hard to tell on the injectors after they are installed they seem to flatten out...
cabloom300
Nov 10, 2013 06:26 PM
Misn 1
Jun 5, 2013 03:35 PM
79sparky
Jan 14, 2013 04:39 PM
Dustmaster
18
Oct 22, 2011 03:03 PM
fslay
WTB - Parts & other
Oct 29, 2010 03:14 PM
