need help id'ing this part
Old Oct 21, 2010 | 09:28 PM
Wiyr's Avatar
Wiyr
well i was backing up my trailer and it was getting real hard to get into Reverse OR Low, i was in 4Lo backing up.. so im guessing its low on fluid, so i wanted to fix the leak before filling it back up
my mechanic told me my transmission (zf-650) was leaking from the top of the transmission so i finally looked under my boot and noticed a bolt of backed out. so i unbolted it and there wasn't a gasket there.. so i put red RTV and started to bolt it back down.. then i saw this. anyone know were to just get the rubber piece or what its called?
Old Oct 21, 2010 | 09:40 PM
camodown's Avatar
camodown
PN F81Z-7277-AC called a 'boot' in the Ford catalog I purchased it from. List $19.98, and it just pops out after you have the shift tower retainer removed. I got it from Ford. The gasket I used was made from Right Stuff by Permatex, works great! Mine boot was slit as well and I noticed fluid leaking out of my trans from the top. Fixed it and was good.
Old Oct 21, 2010 | 09:46 PM
Wiyr's Avatar
Wiyr
there is no way to get it aftermarket?
i just used red RTV for the gasket
Old Oct 21, 2010 | 09:55 PM
camodown's Avatar
camodown
I am not sure aftermarket wise on who would even have it given how rare ZF-6's are. The GMs used a ZF-6 but had a different tower. Try partsguyed if you can wait for it to be shipped, he has Ford parts for less $. I have been burned on non factory parts too many times to really shop around. Plus, don't have the time...
Old Oct 21, 2010 | 09:56 PM
Wiyr's Avatar
Wiyr
didnt know the zf-6 was rare
Old Oct 21, 2010 | 10:45 PM
SpringerPop's Avatar
SpringerPop
There are some times that aftermarket is contraindicated.
There are times you really should go "OEM, BABY!"
This is probably one of them.
Pop
Old Oct 21, 2010 | 11:12 PM
camodown's Avatar
camodown
Well, I reckon 'rare' is a relative term in this case. You will be hard pressed in these parts to find a ZF6 truck, even in a salvage yard. I cruise the listings for trucks and they are a pretty hard to find at least as I have seen. Relative to automatic Ford 7.3 99+ body style I would say manuals are much less common.
Old Oct 22, 2010 | 12:45 AM
Wiyr's Avatar
Wiyr
i sorta agree it took me awhile to find my truck with a zf-6
Old Oct 22, 2010 | 07:39 AM
SpringerPop
After the broken boot allowing sand and dirt to get inside the trans, I'd sure be changing the oil in it a couple of times.
Pop
86F150302
26
Dec 30, 2016 08:25 PM
HI DEF
Jan 22, 2015 01:23 PM
Frapper
General Automotive Discussion
Apr 27, 2012 05:44 PM
Skrilla
Jul 2, 2011 11:30 AM
santacruzf250
26
Nov 13, 2010 11:49 AM
