Already have dream beams but thinking of moving the mount hole up 1 inch to get just a little lower and need to Shortin the spring to correct the Camber
From what I have read on here you can cut up to 2 coils but there are some consequences you may not be able to correct the camber enough and effect tire wear. I would just try 1 coil and see where that brings it in at and go in 1/2 increments from there but no more than 2 coils.
I cut one complete coil off and it was to much, the recommended amount is 1/4 of a coil at a time then re install and check camber, I also heard someone say he switched the upper coil bracket with one from a 3/4 ton truck and it fixed the camber after moving the I Beam brackets, I have been thinking of relocating the I beam brackets as well, that with my cut coils installed should get me where I want to be.... hopefully!
Aftermarket I beams cannot be adjusted for camber or caster. you are stuck to what they fabricated the junk with on the jig.
Stock i beams can be adjusted by hydraulic bending somewhat but will not tolerate much over four degrees of correction.
