5th wheel trailer size question
Old Oct 19, 2010 | 12:20 PM
samahi72's Avatar
samahi72
I have an 84 22' Alpenlite 5th wheel. The tires that are on it right now are 205x75x15. I have no idea what size the factory recommends. I would like to go to a taller tire to get the trailer to be level with the truck (I can't lower the hitch any lower and I don't want to reverse the axles). A couple of questions,
1. Any idea how to find out the original size?
2. Any problem with going to a 225x75x15?
Thank you.
Old Oct 19, 2010 | 12:24 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
Can you still read the GVW metal tag on the trailer. I oftentimes has the original tire size and filling pressure on it.
Old Oct 19, 2010 | 01:22 PM
samahi72's Avatar
samahi72
I don't know, where would I look to find that GVW tag?
Old Oct 19, 2010 | 02:51 PM
senix's Avatar
senix
Sometimes it is near a corner of the trailer or perhaps on the front somewhere near the point to raise the front jacks. perhaps looking inside the cupboards may yield some info.
You will want to go with LT tires btw.
Old Oct 19, 2010 | 04:35 PM
dchamberlain's Avatar
dchamberlain
It might be one of the tags by the door, also.
Old Oct 19, 2010 | 05:11 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
It's possible that back in '84 it wasn't required......is Aspenlite still in business?
Old Oct 19, 2010 | 07:05 PM
samahi72's Avatar
samahi72
I was searching for them on the web and one site said that they are out of business. I was going to call them to see if they could tell me the original size.
Old Oct 19, 2010 | 08:18 PM
RV_Tech's Avatar
RV_Tech
You won't find them. They have been gone for a long time.
Steve
Old Oct 20, 2010 | 05:53 PM
bpounds's Avatar
bpounds
There will be a label on the trailer somewhere. It has been the law for many many years. I've never seen a trailer without one, but sometimes they are painted over.
If the larger tire fits the wheel (check the tire manufacturer for recommended rim widths), and if the tire fit the wheel wells on the trailer, you should have no problem going larger. A 205 to a 225 isn't much of a change. You might also want to weigh the rig, and make sure you are not overloading either the existing tire, or the new tires.
If there is a spare, check the size on it. Often spares don't get changed with the running tires, and it might be a clue to the original size.
Old Oct 20, 2010 | 06:35 PM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
My '94 Prowler never even came with a spare...I doubt if his '84 did either.
Old Oct 20, 2010 | 08:08 PM
senix's Avatar
senix
no spare on my 96 Chateau.
Old Oct 21, 2010 | 06:55 AM
Gearitis's Avatar
Gearitis
I was talking with my Dad last night he's 78 now) and I was also reading FTE and came across this post. I asked him as I remember he had an Aspen lite about that time. He said, that if he rememberd right, it had 7.00x15's 6 ply bias. He remembered he upgraded to 7.00x15 8 plys bias and it pulled better and he was less worried about the weight. He pulled it with a 1967 F-250 that had a 352 in it. So if pops memory is right, that equals to about a 225x75x15 Load range D or E. He pulled that thing to Canada, California, Carolinas and never had any problems with tires. He said he just kept the pressures up. Don't know if this helps, just trying to relate from someone who remembers these things.
Old Oct 31, 2010 | 11:24 AM
GKing's Avatar
GKing
A good tire store should be able to help find the right size and be able to check for propper wheel well clearance for what you want to do.
Old Oct 31, 2010 | 11:34 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
They SHOULD, but most of them now don't have anyone there long enough to learn these things.....and IF one does learn, he goes off and applies it where he can make more money!
jdsnake10
Mar 9, 2015 02:54 PM
F-250 Super Duty
28
Apr 4, 2014 11:00 AM
flamebuster
Sep 25, 2009 12:57 AM
frankovsky
All Things Towing
Oct 25, 2007 05:42 PM
samahi72
All Things Towing
15
Jul 16, 2006 11:54 AM
