Tire sizes???
Old Mar 8, 2015 | 10:12 PM
jdsnake10's Avatar
jdsnake10
Tire sizes???
Just trying to get some info on tire sizes for a 15x7 wheel. The truck is lowered 3/5. Seeing if anyone has a similar set up so I can have an idea before I go to the tire shop. Thanks
Old Mar 9, 2015 | 12:15 PM
Nothing Special's Avatar
Nothing Special
The obvious answer is that it needs to be a 15" tire on a 15" rim.
For width a general rule of thumb is that the tire should be about 1" to 3" wider than the wheel. So on a 7" wide rim you should have about a 8" - 10" wide tire, or about 205 - 255 mm. People do go outside of that range, but I've heard it recommended often enough that I won't recommend pushing farther.
You need to find out what's available and decide on what OD you want. For any given width and rim diameter a lower aspect ratio will have a smaller OD and a larger aspect ratio will have a larger OD.
Old Mar 9, 2015 | 02:54 PM
jdsnake10's Avatar
jdsnake10
Thanks for the info, gonna head to the tire shop today.
bobkonaben
Feb 3, 2015 09:04 PM
emmagator
Nov 19, 2007 09:54 PM
jdennen
Sep 6, 2004 06:48 PM
Longneck
Mar 11, 2004 08:18 AM
smokey-2
Dec 27, 2003 03:28 AM
