Opinions, thoughts and input please,,
Ok,, so the questions I am looking for input on,,,
#1 Should I put the 63 on the 79 frame?
#2 I have a 460/C6 combo,,, should I put that in the original 63 frame and stay with the stock axles (spicer 60 w/4.56 rear,, 44 front,, 4.56) and fix what breaks as I go...
#3 Dump some money into the 292 and the T98 and run it stock
I know the value of the 63 is speculative,,, mostly in my mind, BUT... I am looking for your thoughts on this also,,,pics are in my album/gallery
I have the heads off the 292, had a couple bent pushrods,,, valve seals were shot,, needed freshening,,,
The 460 would get a mild rebuild and C6 rebuilt before install
The 300 would also get a rebuild
This isn't going to be a show truck,,,, just a fun, reliable cruise arounder,,, I would like to paint it to match my Smoker/BBQ I have and pull it with it,,,
Please give me your honest thought and opinions please!
Thanks
Joe
for what it's worth.
Never done a Straight axle Slick swap to a later model chasiss. Its dueable; I would try to determine if oem (63) frame mounting later model axles & place newer drive train in between the rails be easier than frame swap.
Again not a good answer but more of a though. I would keep it title 63, in my case.
sorry no really good help on my behalf as well.
Swapping to something of similar displacement is simply a waste of time and money. Stock for stock, in most cases any increase in power will be negligible if it's there at all when staying close to the same displacement. So far every "modern" 302 equipped slick I've heard the actual fuel mileage for is worse than my stroked and ported 292 so it seems to be a step back there, too. If you're going to swap, go big.
If you're looking for fun and economical, I suggest sticking with the Y. If you're looking for some serious torque, do the 460.
More thoughts on this, after having my first 66 F100 and doing the disc brake conversion, power steering,, and misc,,, (way before this thing called the internet!!) I ended up selling it and buying another 66 F250 and just redid it all,,, left the ol Strong-arm steering, and drum brakes and just made it new,, I loved that one,,, it was how they made it and it worked.
So that is my dilema on the 63.... Factory 4x4... manual steering, manual brakes,,, just put all new in,,, Or the thought of having a Ford 4x4 frame w/PS/PB and just newer components.... but does it detract from the 63 as a whole if I left it all original...
believe me, this is not a big worry of mine,, just was thinking and it has been ticklin my brain for awhile. Not until I have the 63 and 79 side by side will I really be able to see what will work the best.
My original thoughts were to just swap the whole body from the 63 4x4 ONTO the 79 4x4frame,,,, more modern, yet still a Ford and still older,,,
And YES I would keep it titled as a 63,, screw CA and their friggin stupid A$$ smog rules and all the BS with that,,, WHAT A CROC.
https://www.ford-trucks.com/forums/5...is-this-2.html
<TABLE class=tborder id=post4251207 cellSpacing=1 cellPadding=6 width="100%" align=center border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD class=alt2 style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px" itxtvisited="1"><TABLE cellSpacing=6 cellPadding=0 width="100%" border=0 itxtvisited="1"><TBODY itxtvisited="1"><TR itxtvisited="1"><TD noWrap itxtvisited="1">NumberDummy
Ford Parts Guru</TD><TD width="100%" itxtvisited="1"> </TD><TD vAlign=top noWrap itxtvisited="1">Join Date: Nov 2006
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR itxtvisited="1"><TD class=alt1 id=td_post_4251207 itxtvisited="1"><!-- message, attachments, sig --><!-- icon and title -->
<HR style="COLOR: #d1d1e1; BACKGROUND-COLOR: #d1d1e1" SIZE=1 itxtvisited="1"><!-- / icon and title --><!-- message -->VERY RARE
4,273 1963 Ford F250's were made in cab and chassis form. Only 348 were 4X4's.
If this truck came from the factory with the flatbed...795 total were made..of those ONLY 89 were 4X4's.
THe VIN plate should tell you what the original configuration was. Post it here, I can decipher it for you.
Mark
I am thinking about an early 7.3 into the 79, so I wouldnt need to smog it,,, but they don't make an adapter for 7.3 to NP435 and I am not really a fan of autos,,, a friend does have a 90 F250 4x4 7.3/AOD combo,,, AOD needs rebuilt,,,, so many options!!! so little time!
If you cant get a 435 to it you can always use a ZF 5. AOD's are light duty i believe, even though they are not electronic garbage like the E40D, I dont think they can take it. M50D's are pretty weak from what i hear too.
