Tow / haul
Old Oct 19, 2010 | 08:10 AM
WIKD's Avatar
WIKD
Tow / haul
At what weight should you engage the tow/haul on the column? If I'm towing 3000 pounds with a 60hp tow program is it needed to alter the OD?
Old Oct 19, 2010 | 09:59 AM
Gene Horr's Avatar
Gene Horr
1.5 tons won't make a material difference unless you are in steep hills. Just leave it off unless you notice the transmission shifting excessively.
Old Oct 19, 2010 | 12:14 PM
WIKD's Avatar
WIKD
Thanks. Was pretty much what I thought but wanted to make sure. Especially with some of the 6.0L nightmares I've read about.
Old Oct 19, 2010 | 07:59 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Try it both ways. Use which ever one you like better. You won't hurt it either way.
WRABER
Apr 29, 2016 07:30 AM
Patrick M
Nov 2, 2013 01:18 PM
DesMoinesDieselDuty
Apr 25, 2012 02:22 PM
bobbyc257
Jan 24, 2012 09:51 PM
superman724
May 18, 2008 02:46 PM
