tow/haul
Only if you want to. Tow/haul in trucks with the 5R110 is optional, it raises the shift points and engages a sort of exhaust brake with the torque converter and turbo vane control. But the transmission doesn't care if it is in tow/haul or not, it's your choice. I rarely engage it except when I want the engine braking effect.
Here's what my 2007 Ford manual says...
The manual..." To eliminate excessive transmission shifting, activate the Tow/Haul feature. This will also assist in transmission cooling."
Another... " the Tow/haul feature improves transmission operation when towing a trailer or heavy load."
If Ford didn't see the value in the Tow/haul mode, they wouldn't have created it.
I can't imagine ignoring this feature, for whatever reason.
Why would you not use it Patrick? Any benefit in your mind?
For an expert opinion (not just mine or MC5C's) on this topic you can refer to this thread, post #12.
https://www.ford-trucks.com/forums/1...ot-towing.html
The first time you have to panic stop with a trailer attached, you'll clearly understand what Tow/Haul mode does for you when stopping. I railed the brakes at about 55 MPH with about 8000 pounds of trailer behind me. The super aggressive downshifts combined with the TBC and ABS brought everything to a controlled stop very rapidly, so much so that my wife was stunned.
"How did you do that?" she asked. " I stomped the brakes, Red did the rest," I replied.
That is what I do. If it starts to hunt gears I engage tow/haul.
Exactly correct.
Exactly correct.
I would hope everyone with this particular question would take the time and get Ford's opinion, via their manual.
Yes some areas are pretty generic, not here.
In my post I used quotation marks to ensure everyone knew that this wasn't my opinion, but the opinion of Ford.
If they're not the expert, why waste the money to produce an operating manual?
I really do appreciate and value every opinion here...but
Before asking questions, I feel the need to read my manual before I assume a thing.
Does Ford believe it's "easier" as you state, or is safety a factor with the quote info above?
I guess it goes back to the question... Why add a feature or benefit if it isn't a feature or benefit?
It is a feature. Most people that have used tow/haul like towing or hauling with it on. So there is a benefit.
