Sponsored by: Auxito
need som help
Old Oct 18, 2010 | 02:22 PM
cociorvan's Avatar
cociorvan
need som help
I have a 1995 f150 4.6l v8 with 212000 miles on it i regularly maintenance i changed the tranny a year ago and it worked just fine then all the sudden the torque converter just stopped locking so now i do 60mph at 2000 rpms instead of 1500 and so im burning alot of gas what could be wrong with it? is it a sensor or the torque converter? The engine still has alot of power amazing torque
Old Oct 19, 2010 | 06:24 AM
torkum's Avatar
torkum
Sounds like tranny rebuild time with that many miles
Old Oct 19, 2010 | 08:40 AM
cociorvan's Avatar
cociorvan
could it? because the new tranny had less the a 100,000 miles on it when i put it up
Old Oct 19, 2010 | 10:55 AM
Johnny Langton's Avatar
Johnny Langton
There is a solenoid in the trans pan attached to the valvebody on the 4R70W that controls torque converter lockup. It may be bad. It could also be a bad torque converter clutch. Is the OD light flashing on the end of the shift lever?
JL
Old Oct 20, 2010 | 06:00 PM
cociorvan's Avatar
cociorvan
no it doesnt
Old Oct 20, 2010 | 06:03 PM
Johnny Langton
Originally Posted by cociorvan
no it doesnt
It's possible that the bulb on the OD light is bad, or something else is going on. You need a good quality scanner/datalogger to see what's going on. There are several things that can cause the TCC to stay unlocked.
JL
Old Oct 20, 2010 | 06:14 PM
cociorvan's Avatar
cociorvan
If i take it to an advanced auto and hook it up shud i be able to find out the problem?
Old Oct 20, 2010 | 06:35 PM
Johnny Langton
Maybe...but that's a big maybe. Dunno what scanner they're gonna use,and most of the time they use a generic scanner that will not get powertrain specific codes.
JL
chiefn10
Jan 5, 2011 03:33 PM
02GrayPowerStroke
Mar 11, 2010 11:33 AM
Jag Red 54
N. California Chapter
Jan 4, 2010 08:08 PM
Jag Red 54
15
Jan 4, 2010 03:41 PM
redtruckchuck
Jan 1, 2004 09:01 PM
