GRINCH Noise
Old Dec 24, 2009 | 02:25 PM
Jag Red 54's Avatar
Jag Red 54
GRINCH Noise
My buddy just installed a 302 and a C-4 in his 65. The engine was just rebuilt and so was the tranny. A brand new torque converter was installed. I got there late, so I did not see the actual install. Just before they started the engine, they added 5 qt of atf to the tranny. I do not know if they poured any atf into the torque converter before they put it into the tranny.
When they started the engine there was a loud grinding noise. And the tranny was very difficult to get into gear. It sounded like putting a standard into gear when the clutch won't disengage all the way. GGRRRRRRRG
If they did not put atf into the torque converter before installing it, would it cause this problem? Do you think the torque converter is ruined? Should they remove the transmission and put atf into the torque converter now?
Jag
Old Dec 24, 2009 | 03:41 PM
52 Merc's Avatar
52 Merc
Does he have the drive shaft in the end?
Old Dec 24, 2009 | 04:59 PM
vbarker's Avatar
vbarker
When they put the torque converter on the tranny did they make sure it went into the second notch? After you start it on the front shaft it needs to be turned and slide in about another inch maybe to completely lock in.
Old Dec 24, 2009 | 05:37 PM
Jag Red 54's Avatar
Jag Red 54
I did not get to watch them on the install of the TC. They do know to keep rotating until they get the second chunk, but I can't verify that they did it. The drive shaft is installed, but it won't turn the wheels. (They have jackstands on all four corners) Jag
Old Dec 24, 2009 | 05:43 PM
vbarker's Avatar
vbarker
Jag, It could be the torque converter then. I was told to fill mine first before sticking it on the tranny. If they didn't do that then it could be to dry to let the tranny shift correctly.
Old Dec 24, 2009 | 07:10 PM
Old F1's Avatar
Old F1
I would lean (crash!…whoops leaned too far) towards the TQ not being into the front pump dogs rather then the fluid, the TQ will fill quickly from the front pump and even if you pre-filled the TQ (I never have) you can only fill it half full anyway.
Old Dec 24, 2009 | 08:42 PM
GreatNorthWoods's Avatar
GreatNorthWoods
I agree. Many years ago I forgot to fill the torque converter and it caused no problem at all. I just kept pouring fluid in it until it filled up...
Old Dec 25, 2009 | 07:44 AM
HOTWRENCH's Avatar
HOTWRENCH
Noises
It sounds like you have the wrong torque converter ! It depends on which input shaft is in the tranny -- which converter you use , difference in size and spline counts. Sounds like somebody trying to put a stick in gear without the clutch. Swap converters and you should be OK.
I Hope This Helps ---- Hotwrench
Old Dec 25, 2009 | 07:54 AM
Lakotas53's Avatar
Lakotas53
Something here has me confused, I have a C6 behind a 351W and was told to push, rotate the TC till I felt the second clunk so that I would know it was mated up with the pump, which I did. That gave me 1 inch from the edge of the bell housing to the stud boss on the TC. But then once I mated the Transmission to the engine I had to pull the TC back out maybe half an inch to bolt it to the flex plate. Looks like this would disengage the TC from the pump. BTW I have always been taught to fill the TC with a couple of Qts. of fluid before install but the shop that rebuilt mine said you didn't have to. Hey I know this is routine but he did bolt the TC to the flex plate didn't he?
Old Dec 25, 2009 | 08:33 AM
GreatNorthWoods
If so, it wouldn't be the first time somebody forgot to tighten torque converter bolts but that usually makes a rumbling sound rather than a grinch. Don't ask me how I know...
Old Dec 25, 2009 | 09:24 AM
Glenn O's Avatar
Glenn O
The engine wasn't previously a straight drive and someone forgot to remove the pilot bearing from the crankshaft. If so the torque converter wont seat correctly. Good luck
Old Dec 25, 2009 | 07:21 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
I just went through this a few months ago damn bearing!!!!! turned out ok just had to pull the motor and yank the bearing. We never got anyfarther than that so we never tried to start the motor! Hope all works out well.
Old Dec 25, 2009 | 11:14 PM
52 Merc's Avatar
52 Merc
It doesn't pull out far enough for the t/c to disengage. What you are describing is exactly how it is designed to work. You done good. ;-)
Old Dec 26, 2009 | 09:11 AM
HOTWRENCH's Avatar
HOTWRENCH
Torque Converters
Just for the record there are 2 different torque converters for a C4---- Early 66-69 24 spline later 70 up 26 spline. Late converter will will install into early style trans --- makes a grinding noise and won't drive vehicle.
24 Spline converters won't fit into 70 up trannys.
Have A Good Day-------Hotwrench
Old Jan 4, 2010 | 12:43 PM
Jag Red 54's Avatar
Jag Red 54
Hotwrench is the winner. I passed on all the ideas mentioned and when they checked the TC it was a 26 spline. They got the correct TC and the tranny works right!! Thanks for all the input. Another happy ending for FTE. Jag
