converted
Old Oct 17, 2010 | 06:02 PM
MY 390's Avatar
MY 390
Red face converted
Hey ford fans. I have a 68 3/4 f250, 390 with some kind of electriconic ignition, it has been converted. I can not find a modular or box so i think the conversion is in the distributor itself. Question is where do i hook up the green wire from the new summit tachometer i just bought. Will it be safe to hook to the negative on the coil????.
Old Oct 17, 2010 | 06:36 PM
jowilker's Avatar
jowilker
I believe that is correct the green wire goes to the - side of the coil, mine does.
What do you see when you take the cap off the dist.?
John
Old Oct 17, 2010 | 09:19 PM
MY 390's Avatar
MY 390
Smile dizzy
their is a rotor of course, and a small rectangular box with a black and red wire going to the coil. I think that's what i saw. It is pointless.
Old Oct 18, 2010 | 05:10 AM
jowilker's Avatar
jowilker
Anything on the box? I have one that has Petronix & more on it.
John
Old Oct 18, 2010 | 05:48 PM
MY 390's Avatar
MY 390
Smile yes
It shows pertronix as well, and more, hard to read. So that is the module, i assume? So if it is like yours, then to the negative side of the coil should be OK. Thank You very much.
Old Oct 18, 2010 | 06:08 PM
jowilker's Avatar
jowilker
You can check out this site for more & better info Pertronix Performance Products
John
whitezombie70f-100
Feb 10, 2008 11:42 AM
460man
Nov 29, 2005 02:00 PM
kdarling
Oct 12, 2004 11:55 PM
1970 F-250
15
Nov 17, 2003 09:37 AM
anotherF150
Nov 11, 2002 08:51 PM
