HOW MUCH BOOST
Old Oct 16, 2010 | 10:05 PM
ingramdwi's Avatar
ingramdwi
HOW MUCH BOOST
1996 F-350 7.3 PSD 4X4 STOCK.I want order gauges but this is my first diesel and i dont know how much boost the truck should have.will a 35 psi gauge work,are do i need more.any help would be appreciated.
Old Oct 16, 2010 | 10:34 PM
oldbird1965's Avatar
oldbird1965
With my mods I can get 32psi boost. If you get over 40psi then you'll be putting out over 400hp and will need to put in head studs. I would say 35psi gauge would be fine unless you will be going all out in mods. By the way, if they had powerstrokes back in 1196 we should be flying to Pluto by now at warp speed LOL!!
Old Oct 17, 2010 | 01:00 AM
Fullcrew7.3's Avatar
Fullcrew7.3
Glenn's got it. 35 psi gauge should be all you'll need. An 1196, eh? That's an old truck!
Old Oct 17, 2010 | 07:12 AM
Brown Falcon's Avatar
Brown Falcon
Stock you will probably see 15-18 psi at the most.
6637 Intake, 3" downpipe, free flowing exhaust, maybe up to 20psi.
With my setup in my signature I'm seeing 32psi. Once you get over 35psi you'll start frying the stock turbo.
Old Oct 17, 2010 | 11:51 AM
ingramdwi's Avatar
ingramdwi
thanks for the advice,sorry about the typo.Glow shift has gauge pod three gauges e.g.t,trans, boost,and wire kit for 199.oo,is that a good price?
Old Oct 17, 2010 | 12:40 PM
427 fordman's Avatar
427 fordman
Some people like them, some don't. I have them and all was good till the other day and I blew my boost pressue line off. I kicked it out of overdrive and got after it a bit to pass a car with the trailer on and it popped off. It just slides on, its tight but still.. It's a poor design. Gauges have been working good otherwise.
Old Oct 17, 2010 | 03:39 PM
fordpride's Avatar
fordpride
Sunpro CP7050 Sport ST Light Truck Turbo Diesel Gauge Set
Old Oct 17, 2010 | 04:27 PM
Brown Falcon
I'd stay away from Glowshift personally. Autometer, Isspro, Dipricol, or Sunpro
Old Oct 17, 2010 | 09:43 PM
oldbird1965
Darin, ever hear of goop, great stuff!
Old Oct 17, 2010 | 10:01 PM
Krisx125's Avatar
Krisx125
Just installed my guages tonight.. It got late and had an hour drive home so we didnt drill and tap the exhaust probe and water temp. ill finish it tomorrow. fit and finish isnt as nice as the ISS pros but i like these guages. Alot of people around here have them and they say they're spot on. We'll see..
Old Oct 18, 2010 | 03:12 AM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
6637, 3" downpipe, stock exhaust with no muff and CAT, 10k mod and superduty IDM will get you 23psi WOT pulling 7k pounds
Old Oct 18, 2010 | 06:08 AM
427 fordman
I never thought of that glenn. I actually have some of that stuff on the shelf in the shop. I think I'll try that along with a small zip tie for now.
Thanks Glenn
Old Oct 18, 2010 | 08:50 AM
Talyn's Avatar
Talyn
I went big and went for a 50.
Old Oct 18, 2010 | 09:30 AM
oldbird1965
You bet Darin, every tool box should have some, great stuff. I even sealed up a high pressure AC line once good enough to get home to fix it right. When I put it on, I don't mess with it until the next day, it takes awhile to dry all the way through.
