6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
EGR Block Plates..
Old Oct 15, 2010 | 12:33 PM
nomorecummins's Avatar
nomorecummins
EGR Block Plates..
Been hearing of these horror stories of the EGR cooler failing and causing the #8 cylinder to seize. Wondering if I should buy these, for a little better piece of mind.
Thanks
Old Oct 15, 2010 | 02:16 PM
R-T0r21on's Avatar
R-T0r21on
Thanks
I believe you'll also need a tuner/tune that disables the EGR function. The block-off plates will increase the exhaust back preassure, so you might have head gasket problems. It's a gamble either way, but I think the EGR cooler failures you're talking about are few & far between.
If it were me and I was THAT concerned about the possible EGR cooler failure, I'd delete the entire EGR system. Like I said though, you'll need a tuner to make it work w/ no codes thrown.
For what it's worth, I'm considering deleting my EGR system too. Just have to wait til income tax check time......
Old Oct 15, 2010 | 07:57 PM
nomorecummins
Thanks for the input... The tuner I am using DOES delete the EGR. I am still debating though, whether to do it or not...
Old Oct 16, 2010 | 11:47 AM
0835064's Avatar
0835064
Don't bother, I installed them, two weeks later blown headgaskets. Not saying its related but..
Old Oct 17, 2010 | 11:03 AM
nomorecummins
Wow, it's got to be related in someway..
Old Oct 17, 2010 | 12:43 PM
cartmanea's Avatar
cartmanea
With the higher power tunes, some programmers use the EGR system as a wastegate to prevent the high backpressure. What tuner do you use and what power level? You might want to talk with your programmer and see what they do with the EGR, if its off all the time in the programming, then you can go ahead and block it off I think.
Dre82s
Jul 1, 2008 11:09 PM
mooney456
Jun 19, 2005 11:58 AM
JCastellaw
Jan 16, 2004 11:35 AM
steve83
Dec 19, 2002 12:04 PM
thelonerangerxlt
Feb 23, 2002 01:55 AM
