Sponsored by: Real Truck
331 REAR END
Old Oct 15, 2010 | 11:44 AM
RPARKER559's Avatar
RPARKER559
331 REAR END
Anybody have the 250 with 331 rear end in it? If so how does it pull? What kind of Mileage are you getting out of it. Been looking at one but I am hestitant because of the gearing....
Old Oct 15, 2010 | 01:18 PM
cartmanea's Avatar
cartmanea
I wouldn't want gears that tall, even with stock tires.
Old Oct 15, 2010 | 02:05 PM
scububbs's Avatar
scububbs
I believe that gear ratio is only available with the diesel engine, at least in the 2011 models. I'm not sure why, other than the motor produces enough torque to pull the Queen Mary around Lake Havasu, so maybe you don't need higher gearing.
Old Oct 15, 2010 | 02:19 PM
cartmanea's Avatar
cartmanea
Well, if its for a 2011 they have a lower 1st gear in the transmission, so 331 isn't too bad. I still wouldn't go taller than 3.55s though, and with the 5-speed definitely no taller than 3.73s.
Old Oct 15, 2010 | 02:53 PM
senix's Avatar
senix
I would opt for 3.55's, preferable to have a 3.73 but with the new 6 speed auto I think you can get by with the 3.55's.
Old Oct 15, 2010 | 03:20 PM
RPARKER559's Avatar
RPARKER559
Yes it is a 2011 Diesel........will be towing a 31ft Travel Trailers with it. 6700 lbs. Stealership said it would do it just fine but I tend not to believe them.
Old Oct 15, 2010 | 03:23 PM
cartmanea's Avatar
cartmanea
If you'll be in a lot of hilly terrain, or might ever bump up the tire size a little, I'd go with the 3.55s minimum.
REDFORDFX4
2015 - 2020 F150
17
Jun 27, 2021 03:31 PM
Mayberry
Jul 26, 2016 09:21 AM
Paulcal
6.7L Power Stroke Diesel
24
Mar 19, 2016 04:46 PM
ARK Ranger
2009 - 2014 F150
Jul 3, 2013 11:06 AM
