Towing with 3.31 rear end
Old Aug 26, 2015 | 09:28 AM
REDFORDFX4's Avatar
REDFORDFX4
What are you guys with 3.31 gears towing, any disadvantage?
Alot of local dealers seem to order alot of these with the 3.5 eco and the 5.0.
Old Aug 26, 2015 | 09:55 AM
seventyseven250's Avatar
seventyseven250
I don't have a 2015, but I do have the 3.31, so hopefully my experience is helpful.
I went from a 2005 5.4L with 3.73 gears to a 2012 3.5EB with 3.31 gears, and pulling the same trailer on the same ground, the 2012 was far more powerful. I upgraded to a bigger trailer (now 7000 lbs), and I don't find myself lacking for power up hills or when passing.
What I have considered, is that with the 3.31 gears, I'm probably dropping down about one gear further than someone with the 3.73 would need to, but that doesn't bother me.
I climb a lot of hills while towing in 4th gear, and if there is any kind of headwind, I'm in 5th most of the time on the flats.
Now, that's a pretty apples-to-oranges comparison, I realize, but I have been wondering what gears I would buy on my next truck, and I have decided that I would have no problem getting the 3.31's again.
Also, I suspect my empty highway mileage is slightly better with the 3.31's than it would be with the 3.73 or 3.55. Maybe not much, I'm not sure.
Old Aug 26, 2015 | 10:31 AM
Frantz's Avatar
Frantz
If you are buying the truck because you tow often then you should seek out 3.73 (or at least 3.55). If you tow a few times a year and the rest of the time you just drive around then the 3.31 will give you good savings in fuel, and long term you are spinning the motor less so you put that much less wear on the motor as well.
Old Aug 26, 2015 | 06:13 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
I haven't had any issues what so ever but it's important to remember the limitations of your truck. My 2011 with the 3.31's is rated to tow about 9000 lbs.
I can remember not too long ago when the 3.73 LS axle was the go to or must have to make a truck a truck. IMHO, that set up will become a special order or even an obsolete item in the future.
Old Aug 26, 2015 | 07:16 PM
seventyseven250
With the upcoming 10 speed transmission, I don't see the need for a non-commercial truck owner to have the 3.73 gears.
Only kind of off-topic, but does anyone know the planned gear ratios for that 10-speed? I am guessing it'll be a triple overdrive, and have a very deep first gear.
Old Aug 26, 2015 | 07:59 PM
GlueGuy's Avatar
GlueGuy
This came up in another thread, and I think they posted the ratios, or at least a link to a listing of the ratios. unfortunately, I can't remember the thread.
EDIT: Didn't find a thread, but I did find this discussion: Exclusive: An Inside Look At Ford's New 10 Speed Transmission - The Truth About Cars.
It speculates that there will be 6 underdrive gears, one 1:1 gear, and 3 overdrive gears, along with guesses of the approximate ratios.
Old Aug 27, 2015 | 07:23 AM
LSchicago2's Avatar
LSchicago2
3.73 was not available in my combination, but I made sure mine had 3.55's. Dealer had to trade.
Old Aug 28, 2015 | 08:39 PM
rednck21's Avatar
rednck21
I have a 3.5 eb with 3.55's. The dealer gave me a loaner with a 2.7 and 3.31's... I was very surprised at how well it towed!
Old Aug 29, 2015 | 07:02 AM
fordman19762003's Avatar
fordman19762003
my buddy had a 2012 3.5/3.31 and it towed his 6k trailer better than the 5.4/3.55 combo that his '08 had. I believe his 2014 has the 3.31's also.
Old Mar 26, 2016 | 12:59 PM
brokenleg's Avatar
brokenleg
I want to get 3.31s next time. I don't have mountains to deal with and based on my past experiences with trucks, the taller your gears are the better fuel economy will be. (I have 3.73s in my 2013, but if I get another truck, Im keeping the 2013, as its a rare truck..)
Old Mar 26, 2016 | 08:34 PM
GuyGene's Avatar
GuyGene
Right boys, I'm a geezer, so I'm really having to relearn all my old fashioned differential ratio stuff from the '60s era. Actually, there is a whole heap of mess I'm having to relearn... daggoned world keeps changing on on me. Right in front of me old bifocaled eyes.
Old Apr 18, 2016 | 09:27 AM
Rickyrobert's Avatar
Rickyrobert
Just towed 4000lbs with my 5.0 3.31 and it did great 1500 rpms 5 gear and 4th at 2500 on hills
Old Apr 18, 2016 | 01:23 PM
Tnriverside's Avatar
Tnriverside
I have heard it said that the EB is either Eco or Boost. My thoughts are if the gearing is too tall (high) and you using boost then mpg could go down. Just my thoughts.
Old Apr 19, 2016 | 03:14 PM
jasoncar40's Avatar
jasoncar40
I have 3.31's in my 2013 3.5L EB. For just driving around and long trips, I love it. The last longer trip I took was 235 miles each way. Going out got 24 mpg and coming home I got 22 mpg. Have to love that
I used the same truck when I moved to Alaska, and pulled a 14' x 7' enclosed trailer, and averaged 9 mpg over the 3200 miles. If I was pulling a trailer weekly, I would have probably preferred the 3.55's but for my occasional use, the 3.31's work just fine, especially being able manually shift if needed.
Old Apr 19, 2016 | 03:32 PM
Benztechnc's Avatar
Benztechnc
MPG were better, but on the way home I bumped the speed up to 75 for a stretch, so it dropped about .5 MPG average.
